griz
December 5, 2018, 7:34pm
1
Hi All,
I am trying to customize entity color based upon state, which has led me to the following…
Installed Custom-UI using the manual (local) method as described here
To activate, I added the following two lines to my configuration.yaml file:
customizer:
custom_ui: local
However, adding the customizer lines causes Check Config to fail validation (no result is returned).
Any suggestions?
PS: Home Assistant 0.83.2
Thanks!
finity
December 6, 2018, 3:31am
2
I’m assuming you have it in your configuration.yaml file exactly as you have it above.
try this (notice the indent):
customizer:
custom_ui: local
Also you need to get in the habit of posting code snippets per the instructions at the top of the page.
griz
December 6, 2018, 1:54pm
3
Sorry finity, thanks for the quick response.
Unfortunately the code above is not exactly the way it is in the configuration.yaml file, the actual code is
customizer:
custom_ui: local
I restarted HA and got the following error:
via2326
(Nico)
August 7, 2019, 11:45pm
4
Had the same issue, turned out I did not copy the raw init .py but it’s html, problem solved
