Hey there!
I’d like to use Mimic 3 TTS server on the same device that I have Home Assistant OS on. This is because it’s the only device I permanently leave running. Configuring HA to use an existing Mimic server seems pretty simple (it’s Mary TTS compatible). I’m just not sure what the easiest way to install Mimic 3 on my HA device would be.
I’m running a PI 4B with Home Assistant OS.
Hi. I’ve started to put together a (very) early stage version of an add-on. I haven’t quite gotten HA’s builder script to generate any of the docker images, so be warned if you use this, your device will take a while to build the image.
Feedback is welcome, keeping in mind that this is the first working version. Once installed, you can point the marytts integration at it (example in readme).
Add-on repository with mimic3: https://github.com/Oliver2213/ha-addons/blob/285e6e052d591da5798292d305fdea512a95c58a/mimic3-tts-server/README.md
I don’t yet have a ‘my button’, so if you want to try, you’ll need to add it manually from the addons store page.
Hope it helps
Thank you for working on this! What’s the exact repo link to add? I tried a couple of urls in the Add-on store > repositories > manage repositories, but HA doesn’t seem to find a repo at any of them. So far I tried:
https://github.com/Oliver2213/ha-addons/tree/main/mimic3-tts-server
https://github.com/Oliver2213/ha-addons/tree/main/mimic3-tts-server/
In the top-right corner of the Add-On store, you will find the points. There you need to click on Repositories. Then you paste the following URL:
You find the URL when you go to olivers repository>code>clone>https
