i have been using Alexa media player for a while, now i like to update to version, 1.0.x from 0.9.x
to be able to use multiple accounts. the problem is that the installation requires this command:
pip3 install --force git+https://gitlab.com/alandtse/alexapy.git
hi, thank for your reply, it doesn’t work to do like this, kind of annoying since it works withe the 0.9 version, i did manage to run the above script in a konsol and it stats it installs but im getting this on reboot:
Unable to install package alexapy==0.1.0: Could not find a version that satisfies the requirement alexapy==0.1.0 (from versions: 0.0.1, 0.0.2, 0.0.3, 0.0.4, 0.0.5) No matching distribution found for alexapy==0.1.0 You are using pip version 19.0.2, however version 19.0.3 is available. You should consider upgrading via the ‘pip install --upgrade pip’ command.
hi. got it working. very strange. doing the above didn’t work the first times. tested to ad another folder and put the files in that and then it workt.
Great! Glad you got it working.
Pay attention to the messages when upgrading to 0.88 or higher. The structure of the custom component folder changes, so you might need to move and rename these files as I had to do for my life360 custom component.
