How to install Z-Wave.Me RaZberry 7 Pro on HA Yellow
Hi guys! I’m having a Yellow and a friend gave me a Z-Wave.Me RaZberry 7 Pro. Can I install that somehow? Anyone who can give some pointers?
Mounted it on the MB but Im not sure how to make the Yellow recognize it.
The 10x GPIO headers on a Yellow follow the same pinout as the first 10x pins on a RPi, specifically to allow some devices (like the RaZberry) to connect, at least electrically.
https://yellow.home-assistant.io/hardware/yellow-v1.3-standard/
As the RaZberry 7 Pro only uses 10x pins, it should connect.
There may be a mechanical issue, depending on the shape of the add-on (might foul other components) and the case may not fit over the top.
I used to use an original RaZberry on a RPi4, and the main issues were upgrading the coordinator firmware (can only be done using a uSD card containing Z-Wave.Me which was a bit of a hassle as you need to stop HASS, swap cards, reboot, remember how the GUI works, etc), and mapping the serial port through to HASS and Z-Wave JS.
When upgrading to a Yellow, the RaZberry was replaced with a USB device from Aeotec as it was easier.
I’d try installing the Z-Wave JS Add-On and see if it it recognised, then look at the docs for serial port device names.
The Z-Wave JS docs do list the Z-Wave.Me RaZberry 7 Pro as a supported device:
Z-Wave Controllers - Home Assistant
If this helps, :heart: this post!
Worked as a charm. Thank you!
I configured my RaZBerry 7 on a normal Raspberry Pi 3 using ZWay first, so it had latest firmware and was configured for the right country. After that I just installed it directly on the header in the Yellow, as @FloatingBoater suggested, and it worked straight away also.
I know this is an older post, but wanted to jyst say thanks anyway :slight_smile:
