How to install Zigbee2MQTT correctly?
I am trying to install Zigbee2MQTT. However, I see differences in the installation guides. I’m a bit confused Do I need to create a user in Home Assistant like in this video? As far as I understand this data is used by Mosqito broker.
Can you suggest the correct way to install Zigbee2MQTT?
I use Home Assistant OS and want to install zigbee2mqtt as an addon
Home Assistant 2023.1.7
Supervisor 2023.01.1
Operating System 9.4
Without knowing how your HA is setup, we cannot help.
If you are running HA OS then just installing it from the addon section will take care of the integration. You will just need to define what stick you are using. If you are using a docker then it might be different and you will need to make a user first, never used that so i’m not sure.
But again. Give some info first.
