But it seems that the only interface to the temperature is the alert email it sends when either the upper or lower temperature is reached. How would I go about having HA read and parse and email and then generate an event that it could then use to trigger the relay? I did a quick search on HA but the only thing that came up was mailgun - but it seems like overkill for an apparently simple task.
It sounds like I need to do more research on the sensors available. I don’t want to have emails but it was just the output from the sensor I found. I’ll come back after doing some more homework. Thanks for the steer.
I was surprised too. I thought it would be just some standard WiFi chip with a sensor bolted on. If I felt a bit more confident about the electronics I guess I could make my own.
The accutal sensor bit needs to be on a probe as it has to go down a tube into a hot water tank.
Thanks all, I’ve gone for the sonoff as that combines the relay with the sensor which simplifies everything. I had a spare ewelink so I was thinking I could use it as my relay but less moving parts is better.
