How to Integrate Call Box AV-04FD BAS-IP with Home Assistant?
I’m trying to figure out how to integrate a Call Box AV-04FD BAS-IP with Home Assistant, but I’m not sure where to start or how it works. Can anyone guide me through the process or point me in the right direction?
Any help would be really appreciated!
Thanks!
Hi, your starting point would be to know whether this device can be integrated.
Have you found anything about that?
I haven’t found integration yet. Has anyone dealt with something similar or have any idea on how to integrate it with Home Assistant?
Which SIP integration are you referring to?
Do you know how to set it up to receive incoming video calls?
  • How can I reliably trigger the sipjs-card to register and answer the call even if the view is opened after the call has already started ringing?
So you got it working?
I get calls correctly, but it should open the card before calling. If I call before opening the card, I don’t get the call in the card.
Did you try by using the event as a trigger?
I need to receive a call using sipjs-card
