Goal
I am trying to integrate two Govee 5075 BLE thermometers into HA via the official “Govee Bluetooth” integration.
Problem
The issue is that the status of both devices always turns to “not available” and there are no updates of the entities. Whenever I remove the integration, restart HA and add the integration again, the entities have the correct values. After that, the entities do not get updated.
I’ve already spent so many hours on this but am completely stuck… Finding similar issues is quite difficult because the integration of similar devices seems to have changed one or two times. I also followed the steps described under /integrations/bluetooth.
My installation
* Pi4: Raspberry Pi OS Lite 64 bit
* Docker: Home Assistant, Mosquitto and Portainer
* wifi disabled, internal bluetooth of Pi4 enabled
* IR smart meter reader connected via USB
* placed inside the electrical cabinet
* HA version 2023.11.3
Docker config
homeassistant:
image: "ghcr.io/home-assistant/home-assistant:stable"
container_name: homeassistant
restart: unless-stopped
network_mode: host
privileged: true
volumes:
- ./config:/config
- /etc/localtime:/etc/localtime:ro
- /etc/timezone:/etc/timezone:ro
- /run/dbus:/run/dbus:ro
environment:
- TZ=Europe/Berlin
devices:
- /dev/ttyUSB0
So… it looks like HA has access to BT and does see these two sensor devices. It also looks like the sensors are sending updates.
But WTH does HA not receive any updates?
UPDATE
I finally found the solution within the comments of a GitHub issue (at least I wasn’t the only one…): When I initially installed HA I ignored the common Bluetooth integration because I didn’t need it at that point. I assumed that the more specialized “Govee Bluetooth” integration works without the “Bluetooth” integration.
After unignoring Bluetooth and turning off “Passive Scanning” everything works fine
