andyp07
(Andy)
1
Trying to understand the best way to use my floorplan in HA. Looking at all the previous posts there seems to be two methods.
- Using HA-Floorplan - video by Dr ZZZ - two years ago
- Using Picture Elements - more recent video’s
Which is the best one to use and what are the limitations.
I want to use the floorplan to action turning on lights but also see the state of entities such as heating, lights, fans etc with animation.
What is the accepted route today. Is HA-Floorplan no longer used ?
pkozul
(Petar Kozul)
2
Hi @andyp07
Floorplan is alive and well. We recently revamped it. Check out the doco here:
Click on the Examples to see some floorplans in action.
andyp07
(Andy)
3
Hi Petar
Thanks for the response, I have a problem, I’ve looked at the docs and cant see what I am doing wrong.
this is my yaml code:
- title: Floorplan
path: floorplan
theme: Google Dark Theme
panel: true
badges: []
cards:
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: 'custom:floorplan-card'
full_height: true
config:
image: /local/floorplan/examples/home/home.svg
stylesheet: /local/floorplan/examples/home/home.css
log_level: info
console_log_level: info
But this is my dashboard view, as you can see it seems to ignore the settings
Any suggestions ?
pkozul
(Petar Kozul)
4
@andyp07 Sounds good. For any questions & support, you can use the Discussions section on the floorplan GitHub repo.
https://github.com/ExperienceLovelace/ha-floorplan/discussion
andyp07
(Andy)
5
Sorted. Found the the sample CSS file was restricting the size to 700px. Sharing the fix for others to use
