How to integrated Globe Suite smart light blub with Home Assistant?
Hi there
I recently bought a bunch of globe suite smart light blub from Costco. I couldn’t figure out how to add them into home assistant.
Thanks in advance!
They appear to use the Tuya platform. You might be able to use this for cloud control:
Or flash with new firmware for local control using tuya-convert.
Thank you so much! I never knew I can use Tyua app on Globe Suite light !
Slightly different question. How that I have each individual light as entity. I’m able to create a button for each light. But is there way to create a single button control multiple lights (like all the lights in the same room).
Yes there is:
Once again, thank you so much!
Thanks for the info! I followed these steps and managed to see the device in Home Assistant, however it says “35851 (unsupported) by Tuya” and I’m unable to control the light. Did I do something wrong or is it possible that this model just isn’t supported by the integration (it’s an RGBWW filament lightbulb from Globe)? Thank you again.
How did you find the Local Key? I am not able to get this working without it.
