I have two cubes. I’m on the latest version of HA. I’m using ZHA integration. I can pair both, I understand the zha_event stuff. They work fine except after about an hour they both disconnect from HA and I have to pair again. I’ve seen a lot of threads on this topic but no answers. They are all old threads, wondering if there is some magic or a dance I have to perform.
Hi:
Just received my cube and I’m experiencing the same problem. Did you fix it?
No, if you are still within the return period you should do that.
What zigbee dongle are you using?
I was using Xbee3. Just changed to Sonoff dongle and it’s working as expected
