Hello
What i want to do:
Keeping internal state of my monitors [D-SUB,DVI,HDMI] and acting upon automation.
Depending on the internal state need to send different command to change the input.
The pseudo-code should look like:
> #initialization
> var1 = DVI
> if automatization triggered (change to HDMI):
> if var1 in [D-SUB,DVI]
> - open input menu
> if var1 = D-sub
> - go up one in the menu
> if var2 = DVI
> - go down one in the menu
> - click to accept
> var1 = HDMI
I found a hass-variables https://github.com/rogro82/hass-variables package in the net, but i not sure if this is the right way to go?
variable:
Monitor_1_input:
value: "DVI"
Monitor_2_input:
value: "DVI"
Also how to use the created variable in the automation condition?
myle
(StePhan McKillen (Other kiwi Here))
June 12, 2020, 10:36am
2
what about using a inputselect
input_select:
select_output:
name: "select your output"
options:
- 'D - sub'
- 'DVI'
- 'HDMI'
- 'Select one'
initial: 'Select one'
icon: mdi:logout-variant
that give you s drop down list to pick one and the HDMI will be selected
now the automation bit
- id: 'output select changed'
alias: 'output select changed'
- platform: state
entity_id: input_select.select_output
to: 'DVI'
condition: []
this should point down the path
Thank you Myle.
So i should do something like this:
input_select:
Monitor2_input:
options:
- "DVI" # moved to first place so at the first time start this will be the initial value
- "D-SUB"
- "HDMI"
icon: mdi:target
#initial: "DVI" //removed so restore state after reboot
- id: 'Monitor2_Input_HDMI'
alias: Monitor2_Input_HDMI
description: Monitor2_Input_HDMI
- platform: mqtt
topic: RFdemux/GA_remote001e
condition: template
value_template: '{{ input_select.Monitor_2_input != "HDMI" }}' # if already HDMI nothing to do here
- data: {}
# open Menu
- service: switch.turn_on
entity_id: switch.GA_WS_Monitor_2_Relay_5
- service: switch.turn_off
# select HDMI
service_template: >
{% if (is_state("input_select.Monitor_2_input", "DVI")) -%} # select HDMI from DVI menupoint
entity_id: switch.GA_WS_Monitor_2_Relay_2
{%- else -%} # select HDMI from D-SUB menupoint
{%- endif %}
# save
entity_id: switch.GA_WS_Monitor_2_Relay_3
I am not sure how to use the service template part i just found simple examples
Also i am not sure if i can use service with service template
