How to keep track of STATE of dual momentary relays on one device [Gas Logs controller]
I built a gas logs controller. It uses two momentary relays, one to start the flame and the other to turn it off. I looked at some lambda examples, but all the ones I can find are for a single switch. Not sure how to adapt it to keep track of dual switching, or if maybe there is another or better way to do this?
Here is the yaml code:
esphome:
  friendly_name: Gas Logs HVAC
esp8266:
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "blablabla"
ota:
  password: "blablabla"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Gas-Logs-Hvac Fallback Hotspot"
captive_portal:
switch:
  - platform: gpio
    name: "Gas Logs Relay"
    pin: D2 #GPIO2
    restore_mode: ALWAYS_OFF
    interlock: [gaslogsrelayneg]
    on_turn_on:
    - delay: 2000ms
    - switch.turn_off: gaslogsrelay
  - platform: gpio
    name: "Gas Logs Relay Neg"
    pin: D3 #GPIO4
    interlock: [gaslogsrelay]
    on_turn_on:
    - delay: 2000ms
    - switch.turn_off: gaslogsrelayneg
While this works, it obviously always shows in the OFF state.
Here is the device itself:
Any help with this would be most appreciated!
Thank you.
That depends on what you want. One switch to turn the fire on and off?
One switch would be ideal, but not sure how I can accomplish that with the 2s momentary action.
Looking at the link you sent. This would go into my ESPHome code or configuration.yaml? I am kinda new at this stuff.
Look at the URL it is esphome, so that’s where it goes.
The template switch without any state feedback (if you don’t define the lambda) can either run in optimistic mode (last action defines state) or as stateless. In which case you get two push buttons, one for on, one for off.
Ideally you would have some sort of state feedback to tell if the fire was on.
I will drop in this example, edit it and see what happens. Thank you.
If the fire can be controlled outside home assistant (buttons on the fire, remote, etc…) I would highly advise against optimistic mode. It will get out of sync with the actual state. This is why a state feedback sensor is needed.
For now, it cannot. Only the ESP8266 can control it. No external controllers. I tried the lambda code and the new switch follows the 2s delay and doesn’t stay on. I added this to the bottom of the above code.
    name: "Fireplace Switching"
    lambda: |-
      if (id(gaslogsrelay).state) {
        return true;
      } else {
        return false;
    turn_on_action:
      - switch.turn_on: gaslogsrelay
    turn_off_action:
      - switch.turn_on: gaslogsrelayneg
Ok then, remove the lambda and add optimistic: true
That did the trick! I need to read up on this optimistic mode and also state feedback sensors
I have seen on this forum many people building these and a few have ask about how to keep track of the state, but none ever said they got it working in the end.
Thank you and of course until after I do some reading regarding the optimistic mode and state feedback sensors, I will still consider this a work-in-progress.
Thank you!
Eventually I would like to convert this into an HVAC integration. Not even sure where to begin with doing that.
State feedback - best method. The state of the switch depends on the state of a sensor. This way changes outside Home Assistant / ESPHome can be followed.
Optimistic - switch state follows whatever the last action in Home Assistant / ESPHome (turn on / off) was. Will get out of sync with actual state of the device if controlled outside Home Assistant / ESPhome.
Stateless - no state feedback and not in optimistic mode. Shows two buttons instead of a toggle switch. You can press either the on or off button at any time regardless of the state of the device.
d723e203ea3861b41037c65be641da32adc23ccd
I assume this is some type of hardware sensor, or is it possible to save the state in the device itself as a variable?
I clearly understand this one now.
I may experiment with this one.
Yes a physical sensor. Using a variable would be equivalent to optimistic mode.
Looking into flame sensors now. I guess I need to find out if flame sensors are compatible with ESPHome. I think safety is of utmost importance and this project really should require a flame sensor.
Read the whole topic. There is possibly a better option lower down.: Winter is coming - best way to keep an eye on the fireplace?
I read the entire topic. I originally looked for a thermocouple on amazon but was not able to find one. The MLX90614 looks promising.
I have another question. Is it possible to add an LED to this, or use the one already on the ESP8266 to show the state? ie Lit when fireplace is on?
Edit: Found some example code to do this, but not yet working. Can one template state be used to set another template, because this seems to be the case here.
I think the on-board LED is on GPIO2/D4 on your ESP board (A Wemos D1 mini, or clone). So you could define a monochromatic light on that pin:
output:
  - platform: esp8266_pwm
    pin: D4
light:
  - platform: monochromatic
    output: board_led
The only reason for doing that is that you can actually use effects like flashing the LED rather than just turning it on.
A more simple solution that only turns on or off would be a binary light:
output:
  - platform: gpio
    pin: D4
light:
  - platform: binary
    output: board_led
In both cases if you don’t want the light showing up in Home Assistant as a control, remove the name: option from the light config and just leave the id:. The output config will not show up as a control in Home Assistant, even with a name.
In either case you add it to your template switch like this
    turn_on_action:
      - light.turn_on: onboard_led
    turn_off_action:
      - light.turn_off: onboard_led
The turn on and turn off actions of the template switch can accept a list of actions to do. So no need for another template. The turn_on action is where you would use an effect action if you used the first light config and want this.
If it turns out you can not control the on-board LED on D4, look up the schematic of your board and adjust the GPIO pin as necessary. Or add your own LED (and current limiting resistor) to another pin. Keep in mind there are GPIOs you should not use. See the table lower down on this page: ESP8266 Pinout Reference: Which GPIO pins should you use? | Random Nerd Tutorials
What an awesome explanation! It is obvious you are very well acquainted with ESPHome programming. I opted for the simple solution as I really don’t need any light effects. This worked perfectly. Well, it didn’t at first. Once I added the new code the Lovelace switch started to turn back off after a few seconds, even though off had not been triggered. I fought with this for about an hour before I ended up simply rebooting Home Assistant. Everything worked fine after that. Weird.
Thank you and here is my complete yaml code after adding both the optimistic mode and the LED control.
esphome:
esp8266:
  board: nodemcuv2
# Enable logging
logger:
api:
  encryption:
    key: "blablabla"
ota:
wifi:
  ap:
captive_portal:
output:
  - platform: gpio
    pin: D4 #GPIO2 Built in LED
    inverted: true
light:
  - platform: binary
#    name: "On-board LED"
    output: board_led
switch:
  - platform: gpio
    name: "Gas Logs Relay" #Positive polarity +5vdc
    pin: D2 #GPIO2
    on_turn_on:
    - delay: 3000ms
  - platform: gpio
    name: "Gas Logs Relay Neg" #Negative polarity -5vdc
    pin: D3 #GPIO4
    on_turn_on:
    - delay: 3000ms
    optimistic: true
    turn_on_action:
    turn_off_action:
That was odd. You can also reload the ESPHome Integration in Setings → Devices & Services. Click on the ESPHome card then click the three dots icon next to your device:
It’s a lot less extreme than “rebooting”. From least to most invasive to your system:
  • Reload Integration (or config): reload the integration/config for just the single integration/device.
  • Restart Home Assistant: Restart the Home Assistant container and all integrations.
  • Reboot host: shut off the hardware and restart. This stops everything down to the hardware level. Don’t confuse “reboot” with “restart home assistant”. Two very different things.
