I tried to send a command through mqtt (start-process spotify) but the receiving end Hass Agent does nothing. What I’m trying to do is open a Microsoft app (spotify) which doesn’t have a normal installation exe. In terminal I can run the command, but mqtt doesn’t seem to do it.
Here’s the flow:
"id": "2ea56165d99081e7",
"type": "server-state-changed",
"z": "cb7f694f30c3378d",
"name": "When Spotify Plus is Turned On",
"server": "b3afb4a3.474b18",
"version": 5,
"outputs": 2,
"exposeAsEntityConfig": "",
"entityId": "media_player.spotifyplus_marco_emmanuel",
"entityIdType": "exact",
"outputInitially": false,
"stateType": "str",
"ifState": "on",
"ifStateType": "str",
"ifStateOperator": "is",
"outputOnlyOnStateChange": true,
"for": "0",
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": true,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 170,
"y": 780,
"wires": [
"33a8fa0c07bce8cc"
"id": "33a8fa0c07bce8cc",
"type": "change",
"name": "Set Payload Launch Spotify PC",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "\"homeassistant/button/NerdBox/Launch_Windows_Program/action\"",
"tot": "json"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "start-process spotify",
"tot": "str"
"t": "set",
"p": "qos",
"pt": "msg",
"to": "0",
"tot": "str"
"t": "set",
"p": "retain",
"pt": "msg",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 470,
"y": 780,
"wires": [
"a9b7510f20d66b5d"
"id": "a9b7510f20d66b5d",
"type": "mqtt out",
"name": "MQTT Publish",
"topic": "",
"qos": "",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "a9e2a0b33821f130",
"x": 760,
"y": 780,
"wires": []
"id": "b3afb4a3.474b18",
"type": "server",
"name": "Home Assistant",
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|on|true|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "25",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "id",
"statusSeparator": "",
"statusYear": "hidden",
"statusMonth": "hidden",
"statusDay": "numeric",
"statusHourCycle": "h12",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
"id": "a9e2a0b33821f130",
"type": "mqtt-broker",
"name": "mqtt",
"broker": "localhost",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "5",
"keepalive": "60",
"cleansession": true,
"autoUnsubscribe": true,
"birthTopic": "homeassistant/status",
"birthQos": "0",
"birthRetain": "true",
"birthPayload": "online",
"birthMsg": {},
"closeTopic": "homeassistant/status",
"closeQos": "0",
"closeRetain": "true",
"closePayload": "offline",
"closeMsg": {},
"willTopic": "homeassistant/status",
"willQos": "0",
"willRetain": "true",
"willPayload": "offline",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
