How to limit update rate of local push sensors?
Manage sensors’ update rate
Actual situation
Polling sensors
With polling sensors home assistant can limit the rate of polling using scan_interval
With Local push sensors
Local push sensors send data whenever they want. If the frequency of update is high, the system is flooded with updates that make the DB incredibly huge. High update frequency can also slow down the system and increase the cpu load.
Solution: scan Interval on local push = ignore some updates
If I ask why scan_interval is absent on local push sensors, people say that is not possibile to implement because home assistant behave passively and cannot stop sensors from sending the data.
  • Why home assistant doesn’t ignore sensor updates that falls out of scan interval?
  • Why I have to accept the fact that I can’t control how many states are written to a DB?
Examples
  1. Mqtt sensors: I have a meteo station connected using mqtt sensor and the update rate is about 1 update every 30 seconds!!! My DB is suffering as you can imagine
  2. Ble sensors: Using ble sensors the sensor sends data to home assistant every minute and also in this case I have to record all the data because I cannot ignore updates
7000 updates in 1 hour, it’s a crazy amount of messages
