I got a EGLO connect.z Smart Home Remote Control 2.0 from amazon to have a way of controlling my HASS from a wide radius when the network shits itself. Initially i hoped it would just expose every button as entity so i can just listen to the button press in automations. But it only exposes some unuseful entities sadly. Now i know that the commands from the buttons have to go through zigbee so HASS must recieve them at some point so i was wondering how i can get HASS to catch those and use them. I was told there was a trick with listening to zha_events on http://homeassistant.local:8123/developer-tools/event but sadly that does not trigger anything for me and another person i asked to test it.
Are all the events from this remote recognised by ZHA? I can’t see it on the Blackadder list (although that doesn’t mean it won’t work - just that nobody has tried it). There are no references to it in the ZHA device handlers issues list either.
It does appear to be supported by Z2M:
You may have to find or construct a custom quirk.
@Stiltjack Can you test the zha_event monitoring in dev tools? I don’t have ZHA setup on any of my instances here, so I can’t test it. But, it’s curious to me that @Bluscream doesn’t see any events coming in on the zha_event bus. ![]()
I have found the code where they seem to implement the remote:
Sadly i am not knowledged enough to know how to convert any of this to a custom quirk myself. Any help would be appreciated. I am going to attach some logs and debug files/events
Since i cannot attach non-images here i uploaded the files at Zigbee zha EGLO 99099 3 groups remote controller debugging · GitHub
I have also found a custom quirk PR that supposedly adds support for the device at Issues · zigpy/zha-device-handlers · GitHub, but none of the identifiers from any of my debug logs appear in that, instead it says TLSR82xx which i cant find anywhere for my remote
So in the end i got it to work by buying a second Zigbee stick and running Zigbee2MQTT only for the remote control. I have taken some time to create quite a elaborate Automation for it so if it saves someone in the future some time, here you go. It requires a input_number.zigbee_remote_profile number helper that allows for different layouts to be switched to so the remote can theoretically have a infinite number of buttons
alias: Zigbee Remote Buttons
description: Handles various actions triggered by Zigbee remote buttons
- platform: mqtt
topic: zigbee2mqtt/Zigbee Remote Control/action
condition: []
- choose:
- conditions:
- condition: state
entity_id: input_number.zigbee_remote_profile
state: "1.0"
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ trigger.payload == \"color_temperature_step_up\" }}"
sequence:
- service: fan.toggle
entity_id: fan.ventilator
data: {}
- conditions:
value_template: "{{ trigger.payload == \"color_temperature_step_down\" }}"
sequence:
- service: switch.toggle
entity_id: switch.timos_a_c_socket_switch
data: {}
- conditions:
value_template: "{{ trigger.payload == \"brightness_step_down\" }}"
sequence:
- service: light.turn_on
brightness_step_pct: -25
entity_id:
- light.ceiling_light_local
- conditions:
value_template: "{{ trigger.payload == \"brightness_step_up\" }}"
sequence:
brightness_step_pct: 25
entity_id: light.ceiling_light_local
- conditions:
value_template: "{{ trigger.payload == \"recall_1\" }}"
sequence:
- service: light.toggle
metadata: {}
data: {}
entity_id:
- light.floodlight_api
- conditions:
value_template: "{{ trigger.payload == \"recall_2\" }}"
sequence:
entity_id: switch.timo_pc
data: {}
- conditions:
value_template: "{{ trigger.payload == \"red\" }}"
sequence:
color_name: red
entity_id: light.my_lights_color
- conditions:
value_template: "{{ trigger.payload == \"green\" }}"
sequence:
color_name: green
- conditions:
value_template: "{{ trigger.payload == \"blue\" }}"
sequence:
color_name: blue
entity_id:
- light.my_lights_color
- conditions:
value_template: "{{ trigger.payload == \"refresh\" }}"
sequence:
entity_id: switch.party_my_lights
data: {}
- conditions:
value_template: "{{ trigger.payload == \"off\" }}"
sequence:
data: {}
- conditions:
- condition: state
state: "2.0"
sequence:
- choose:
- conditions:
sequence:
data: {}
- conditions:
sequence: null
- conditions:
sequence: null
- conditions:
sequence: null
- conditions:
sequence: null
- conditions:
sequence: null
- conditions:
sequence: null
- conditions:
sequence: null
- conditions:
sequence: null
- conditions:
sequence: null
- conditions:
sequence:
metadata: {}
data: {}
entity_id:
default: []
mode: queued
max: 10
Just want to add my 10ct here:
I use three atumations for the Awox/Eglo 99099 remote control. One for each button group.
No need for a input number helper. Btw. how is that helper set in the code above?
Working sample code for Group1 is below.
For other groups just copy the code and change the group value in this line:
value_template: “{{ trigger.payload_json.action_group == 32778 }}”
Group1 = 32778, Group2 = 32779, Group3 = 32780.
alias: Eglo99099 Remote Group1
description: Eglo99099 Remote Tasten Group1
triggers:
- trigger: mqtt
topic: zigbee2mqtt/Remote Eglo99099
payload: "on"
value_template: "{{ value_json.action }}"
- trigger: mqtt
payload: "off"
- trigger: mqtt
payload: green
- trigger: mqtt
payload: red
- trigger: mqtt
payload: blue
- trigger: mqtt
payload: refresh
- trigger: mqtt
payload: brightness_step_up
- trigger: mqtt
payload: recall_1
- trigger: mqtt
payload: color_temperature_step_up
- trigger: mqtt
payload: brightness_step_down
- trigger: mqtt
payload: recall_2
- trigger: mqtt
payload: color_temperature_step_down
conditions:
value_template: "{{ trigger.payload_json.action_group == 32778 }}"
actions:
- choose:
- conditions:
- condition: trigger
id:
- Group1On
sequence:
- action: light.turn_on
metadata: {}
data: {}
entity_id: light.ceilinglight_eglo
- conditions:
id:
- Group1Off
sequence:
- action: light.turn_off
metadata: {}
data: {}
mode: single
Late reply, but I just bought the same remote and ran into this exact issue, so here is my fix.
In Z2M go to Settings, Advanced, scroll down to “MQTT output type” and set it to attribute_and_json now you can find the profile.
Now all buttons in all three sets work for me.
Some update brought a full “device” into homeassistant for the remote, which makes the automation more readable:
description: >-
trigger.payload_json.action_group 32778, 32779, 32780
triggers:
- domain: mqtt
device_id: 9d6eaf35be89529a8524491a4c4bde78
type: action
subtype: "on"
trigger: device
- domain: mqtt
type: action
subtype: "off"
trigger: device
- domain: mqtt
type: action
subtype: red
trigger: device
- domain: mqtt
type: action
subtype: blue
trigger: device
- domain: mqtt
type: action
subtype: green
trigger: device
- domain: mqtt
type: action
subtype: refresh
trigger: device
- domain: mqtt
type: action
subtype: refresh_colored
trigger: device
- domain: mqtt
type: action
subtype: brightness_step_up
trigger: device
- domain: mqtt
type: action
subtype: brightness_step_down
trigger: device
- domain: mqtt
type: action
subtype: brightness_stop
trigger: device
- domain: mqtt
type: action
subtype: recall
trigger: device
- domain: mqtt
type: action
subtype: color_temperature_step_up
trigger: device
- domain: mqtt
type: action
subtype: color_temperature_step_down
trigger: device
- domain: mqtt
type: action
subtype: recall_2
trigger: device
conditions: []
actions:
- choose:
- conditions:
sequence:
- target:
action: fan.toggle
- conditions:
sequence:
- target:
action: switch.toggle
- conditions:
sequence:
- data:
brightness_step_pct: 20
entity_id:
- conditions:
sequence:
- data:
brightness_step_pct: -20
entity_id:
- conditions:
sequence:
- target:
entity_id:
- switch.esphome_timos_room_flood_light_relais
- conditions:
sequence:
- target:
enabled: false
- action: input_boolean.toggle
entity_id: input_boolean.space_heater_timer
- action: script.buzz
- conditions:
sequence:
- data:
color_name: red
- conditions:
sequence:
- data:
kelvin: 2000
- conditions:
sequence:
- data:
color_name: blue
entity_id:
- conditions:
sequence:
- data:
color_name: white
brightness_pct: 100
entity_id:
enabled: true
- conditions:
sequence:
- target:
entity_id: switch.esphome_timos_room_smart_light_relais
- action: notify.blus_notify_devices
message: "{{ trigger.to_state.attributes.event_type }}"
enabled: false
mode: queued
max: 10
Can you elaborate on this?
How do i get a full device into home assistant
this just happened with one of the updates for either hass core or a component, not something i actively did
