How to listen to an MQTT topic in automation
I’ve created an automation that triggers a secondary automation to send notification via notify or sms service. The second automation is like a notification service that decides whether to send an SMS or notification based on HA. So any automation that needs to send notification will call this service. I first publish to an MQTT topic (in the first automation) and then want to listen (or use that) in the second notification service but I am unable to call or listen to an MQTT service topic … any idea how to do that ?
… and if that is not possible… what is a better approach of passing data from one automation to another ?
alias: "Notify: Garage door open"
description: ""
  - platform: state
    entity_id:
      - binary_sensor.zone_9
    for:
      hours: 0
      minutes: 5
      seconds: 0
    to: "on"
condition:
  - condition: or
    conditions:
      - condition: time
        before: "08:00:00"
        after: "18:00:00"
        weekday:
          - mon
          - tue
          - wed
          - thu
          - fri
          - sat
          - sun
      - condition: time
        before: "17:00:00"
        after: "09:00:00"
        weekday:
          - fri
          - thu
          - wed
          - tue
          - mon
  - service: mqtt.publish
      qos: 0
      topic: garage/status
      payload: " Garage left open on {{now().strftime(\"%a, %d-%b-%y at %-I:%M %p\")}}"
      retain: true
  - service: automation.trigger
      skip_condition: false
      entity_id: automation.trigger_sms_or_notification
mode: single
second service
alias: "Trigger: SMS or Notification"
description: ""
trigger: []
condition: []
  - if:
      - condition: or
        conditions:
          - condition: time
            before: "08:00:00"
            after: "21:00:00"
            weekday:
              - mon
              - tue
              - wed
              - thu
              - fri
          - condition: time
            before: "10:00:00"
            after: "21:00:00"
            weekday:
              - sun
              - sat
    then:
      - service: notify.sms
          message: MQTT topic value in here...'
          target: 0xx
        alias: >-
          Call a service 'Notifications: Send a notification with sms on
          0xx
          message: 'MQTT topic value in here...'
          target: 0xxx
        alias: >-
          0xxx
        enabled: false
    else:
      - service: notify.mobile_app_pixel_pro
          title: Warning!
      - service: notify.mobile_app_a_iphone
          title: Warning!
        enabled: false
mode: single
Your trigger should be
platform: mqtt
You can add condition for state like
  - condition: template
    value_template: "{{trigger.payload_json["yourvalue"] == thestate }}"
I would need to see message to know what to put in the fake value above
Based on your suggestion I created a JASON payload with state as one of the element and then the message.
      qos: 0
      retain: true
      payload: >-
        {"state":"Open", "message":" Garage left open on {{now().strftime(\"%a,
        %d-%b-%y at %-I:%M %p\")}}"}
the above payload was not working so had to change it to simple
 payload: >-
        {"state":"Open", "message":" Garage left open on"}
but HA YAML transformed this with additional escape characters:
payload: "{\"state\":\"Open\", \"message\":\" Garage left open on \"}"
and the second automation is like that
alias: "Notify: Test"
description: ""
  - platform: mqtt
condition:
    value_template: "{{trigger.payload_json.state =='Open'}}"
  - service: notify.mobile_app_pixel_8_pro
      title: Warning!
      message: Test message
    enabled: true
mode: single
Although it worked but how to fix the payload
  • One automation manually triggering another automation is an anti-pattern (i.e. not a best practice).
  • You don’t pass data from one automation to another, you pass it from an automation to a script.
  • An automation without any triggers isn’t an automation, it’s effectively a stunted script.
Simply create a script for sending notifications. Your automation simply calls the script and passes it data via script variables. There’s no need for MQTT or for employing an anti-pattern. You don’t even need to pass the data in JSON format.
Reference
Passing variables to scripts
Taras is correct. Wasnt paying attention
Why do you use 2 automations? These two automations should be combined into a single automation. Not sure why you using 2.
EDIT
Pretty sure you can almost take the entire second automation and add it to the first in place of the mqtt.publish action call
Thanks , and I agree to the script option. I m now calling a script
  variables:
    message: " Garage left open on {{now().strftime(\"%a, %d-%b-%y at %-I:%M %p\")}}"
  entity_id: script.test_script
Instead of dummy message, how do I pass the variable from the automation to script in here:
sequence:
      title: Warning!
      message: "{{message}}"
    enabled: true
mode: single
Doesn’t your example already pass a variable to a script?
It’s passing the variable message to script.test_script and the script is referencing message’s value by employing it in a template like this {{ message }}.
Sorry, it does, forgot to update my reply. Thanks
