Can someone please tell me where this functionality is now?
I could also recommend to use MQTT explorer, a free tool…depends a bit what you want to achieve
I can’t see how to listen with this solution.
Do you have the MQTT integration installed? The integration has a location to add the topic you want to listen to, then press “start listening” and if a payload is found at that topic it is displayed. This is what is shown with the images in the solution.
found it! thanks.
