To switch the audio input on the media player I need to load a local link in a script or automation, how can I do this in Home Assisstant ?
Set ut a restful command
Then you should be able to call this command from the script
Can you show me example of the script with
url: https://slack.com/api/users.profile.set
method: POST
in the help I can see only configuration.yaml or automation
The action is the same.
Or use the gui and it will help you
what’s the name of the action?
what to select in the gui ?
when I try it in gui for script I see nothing
did you restart HA after adding it to configuration.yaml?
No because I didnt add anything in configuration.yaml
in help for configuration.yaml I see this but its not look like useful thing
# Example configuration.yaml entry
rest_command:
example_request:
url: "http://example.com/"
To use this integration, add the following lines to your
configuration.yaml
file. After changing theconfiguration.yaml
file, restart Home Assistant to apply the changes.
What the following lines where can I find it ?
Just replace it with your URL and it should work.
rest_command:
example_request:
url: "https://slack.com/api/users.profile.set"
method: post
I dont understand if I add my url in
rest_command:
example_request:
how its help me call the url from script ?
It creates an entity I believe. Or if it’s just a service call…
now its finally works!
Is it right that I should always add all my url’s to configuration.yaml ? and then use them by the name I set for them ?
I believe so…
