I am relatively new to HA and just learned about Watchman. I have installed and run the report which reports over 200 entities missing, unavailable, or unknown. Almost every one shows it is located in the dwains-dashboard/configs/entities.yaml file.
I have searched and found one post Help finding things in Watchman report please that didn’t seem to address this issue. Can anyone aid in how I can locate and clean up these missing items?
Most of those are probably examples which don’t actually exist in your setup.
activate:
description: Activates an Entity Controller. Turns on the entity and transitions
to the active_timer state. This also clears the blocked state if set.
fields:
entity_id:
description: Name(s) of entities to trigger.
example: 'entity_controller.motion_light'
clear_block:
description: Clears the blocked state of an Entity Controller, if set
fields:
entity_id:
description: Name(s) of entities to change.
enable_block:
description: Enables the blocked state of an Entity Controller, if timer is active
fields:
entity_id:
In Watchman settings you can set ignored files to:
Thanks, I did find some info on ignoring, I’m a little OCD, so it felt like I was just sweeping things under the rug if I ignored them as opposed to fixing them.
