Hi, I like to compare an sensor value with a helper value.
The sensor value comes from a esp32 that is connected with mqtt to home assistant. Sometimes the esp32 is not connected anymore with home assistant and then the entity does’nt change anymore.
So, I like to compare every 20 minutes if the sensor value now is the same value as in the helper. Is it different then put the value now in the helper value. Is it the same, give an error. ( like a whatsapp that the sensor is down => sending a whatsapp is already working) .
But I don’t know where to start how to compare the 2 values. Is there some help?
