Hello everyone, currently is there a method to perform a rescue of the coordinator Sonoff USB3.0 CC2652P in Zha?
I would like to be able to back up the coordinator so that you can restore in case of problems or firmware updates.
thank you
thank you
Should work with Daily Zigbee Coordinator Backup Blueprint - ZNP - ezsp/bellows .
FYI, 2022.9 version of Home Assistant features a new UI and backend/core functions for the ZHA integration to export/save or import/restore Zigbee network ZHA backup images from within Home Assistant’s UI (in the GUI for the ZHA integration) → 2022.9: Home Assistant Birthday Release! - Home Assistant
