As you can see on this screenshot, i have a zeegbee RGB light which i can command with HAss.
My problem : this light is also connected on a relay on another integration1 and i would like the switch to put on or off the relay instead of sending a zigbee command wich will be used only to change the color.
I didn’t find in the documentation how to change it by code or UI.
Could anybody help me find this doc or tell me if it is (im)possible ?
Thanks for your reading.
Regards.
(1) a wall switch, integrated with a HACS integration - GCE IPX800 for information
