ghare
July 12, 2022, 12:43am
1
Hi!
I currently have a shelly installed on my electric board, and it’s taking good measurements and telling me how much I spent in that day (since i told hassio how much 1 kWh is).
But I would like to have a card on my dashboard that accumulates how much I spent everyday until it’s pay day (day 3 of every month).
Could anyone help me out on this? Kinda a big noob around here eheh.
Thank you so much for your time!
Create a utility meter that resets on the third of each month ( Crontab.guru ) using the shelly usage sensor as it’s source
utility_meter:
electricity_imported_billing_month:
source: sensor.shelly_usage
name: Electricity Imported Billing Month
cron: 0 0 3 * *
Create a template sensor that takes the utility meter sensor and multiplies it by the electricity price.
template:
- sensor:
- name: "Electricity Cost Billing Month"
unique_id: electricity_cost_billing_month
unit_of_measurement: "$"
state: {{ states('sensor.electricity_imported_billing_month') | float(0) * 0.12345 }}
You can then use that sensor however you like. An entities card, a graph, a guage etc.
If you are in the UK you can also incorporate your standing charge (using input_numbers) like this :
sensors:
monthly_cost_tracked:
friendly_name: "Energy Cost Monthly"
unique_id: energy_cost_monthly
unit_of_measurement: "£"
value_template: >-
£{{((states('sensor.energy_usage_monthly')|float(default=0)*states('input_number.kwh_cost')|float(default=0)) + (states('input_number.standing_charge')|float(default=0)*now().day|int(default=0)))|round(2)}}
End result :
Yep it can be very complex if required. I have 6 tariffs and a daily charge to consider personally.
ghare
July 12, 2022, 7:37pm
5
SgtBatten:
utility_meter
This definitely helped and I think it did the job, Well… now I have to wait for September 3 Thank you so much!
UK user here
what would be the code to use for a dual tarrif?
im 44p during 5:30am-11:30pm and 10p during 11:30pm-5:30am
please?!
also which file / directory im i editing here for this sensor?
At minimum, you need a utility meter which has two tariffs and the source sensor is your electricity usage
Then you need an automation which changes the tarrif on that utility meter at the appropriate times (time triggers) so your one usage sensor gets split between the two tarrifs at appropriate times.
Then you need a template sensor which does the calculation of the cost for you. multiplying the lower tarrif usage by the lower tarrif and the higher tarrif usage by the higher tarrif and adding them together to give a daily usage.
@SgtBatten
I have utility meter installed and the source sensor is my daily eletric usage.
If i start basic and just add in a flat rate this is where things get stuck for me.
Where would i find the calculation for the sensor and where would i use this sensor?
Post what you have so far
Here is how I track my very complex tariffs [GUIDE] Australian Electricity Demand tariffs (e.g AGL)
You will need to create a utilty meter with the two tariffs for the energy usage:
utility_meter:
electricity_imported_power_daily:
source: sensor.electricity_imported_power_kwh
name: Electricity Imported Power Daily
cycle: daily
tariffs:
- peak
- off-peak
Then an automation to set the tariff at the correct time:
alias: Set Electricity Tariff
description: ''
- platform: time
at: '05:30:00'
- platform: time
at: '23:30:00'
- platform: homeassistant
event: start
condition: []
- service: select.select_option
option: >-
{% set t = now() %} {%- if t.hour < 5 or (t.hour = 5 and t.minute < 30) or (t.hour = 23 and t.minute >= 30) %}
off-peak
{%- else -%}
peak
{%- endif -%}
entity_id:
- select.electricity_imported_power_daily
mode: single
Then a template sensor to add the costs together
template:
- sensor:
- name: Total Daily Electricity Cost
icon: mdi:currency-usd
state_class: total_increasing
device_class: monetary
unit_of_measurement: $
state: >
{% set supply = 0.xx %}
{% set offpeak = states('sensor.electricity_imported_power_daily_off_peak') | float(0) * 0.10 %}
{% set peak = states('sensor.electricity_imported_power_daily_peak') | float(0) * 0.44 %}
{{ (supply + offpeak + peak) | round(2) }}
You can easily adapt this for monthly etc.
SgtBatten:
off-peak
thanks very detailed and helpful
im getting an error on creating the sensor as i think the method/syntax has changed?
my other sensors are set like this
sensors:
solar_pv_voltage_total:
friendly_name: "Combined Solar PV Voltage"
unit_of_measurement: 'V'
value_template: '{{ states("sensor.solax_pv_voltage_1") |float + states("sensor.solax_pv_voltage_2") | float }}'
your sensor I have set like this to try and conform to the new syntax but getting error
sensors:
monthly_eletric_cost3:
friendly_name: "Total Daily Electricity Cost"
unit_of_measurement: '£'
state: >
{% set offpeak = states('sensor.smart_meter_electricity_import_today') | float(0) * 0.10 %}
{% set peak = states('sensor.smart_meter_electricity_import_today') | float(0) * 0.44 %}
i have also created 2 utility sensors
That both reference sensor.smart_meter_electricity_import_today
My template sensor is the new format. Your others are the old format. Template docs
You should create One utility meter with two tarrifs. Not two seperate utility meters. It will give you two sensors, one for peak and one for off peak. (Or whatever tariff names you choose)
You need to set the supply charge (I put 0.xx as an example only.) If you do not have a daily supply charge, set it to 0 or fix the template to remove references to supply.
Ok i have deleted and re-created utility meter with off-peak & peak in the tarrif section.
but im still struggling to get the template sensors in the right format to work in conjunction of my other sensor code
template:
- sensor:
unit_of_measurement: £
state: >
{{ (offpeak + peak) | round(2) }}
I’ve simplified it a bit in case the supply was causing you issues.
It’s already in the right format. Put it in configuration.yaml
It won’t work in sensors.yaml (assuming you are doing it that way) because it’s not a sensor integration it’s a template integration.
You just need to change the peak and off-peak sensor names to match the utility meter tariff ones you should now have
tomcoleman
(Tomcoleman)
March 24, 2023, 11:26am
16
i get this error when putting in configuration.yaml
- platform: waste_collection_schedule
source_index: 0
name: Rubbish # Change this to whatever you want the UI to display
details_format: generic
date_template: '{{value.date.strftime("%A %d %B %Y")}}' # date format becomes 'Tuesday 1 April 2022'
value_template: 'in {{value.daysTo}} days'
source_index: 1
name: Recycling # Change this to whatever you want the UI to display
source_index: 2
name: Garden # Change this to whatever you want the UI to display
template:
- sensor
state: >
I missed a colon after the word sensor
tomcoleman
(Tomcoleman)
March 26, 2023, 11:04am
18
so i now have set
template:
- sensor:
- name: Total Monthly Electricity Cost
state: >
{% set offpeak = states('sensor.utilitymeter_monthly_cost_off_peak') | float(0) * 0.10 %}
{% set peak = states('sensor.utilitymeter_monthly_cost_peak') | float(0) * 0.44 %}
which shows me
not sure why its showing £12
It’s just doing math. So what’s the utility meter entities saying?
tomcoleman
(Tomcoleman)
March 26, 2023, 11:42am
20
i presume its only making a calc from 25th march
