How to make a network monitoring card
I have sensors upload/download. How create similar card?
Image taken from here Netdata - Home Assistant
Here is my network monitopring dashboard, that has charts simililar to what you want to achieve:
And here is the code for just the chart part of monitor card:
            - type: custom:apexcharts-card
              update_interval: 5s
              graph_span: 5m
              show:
                loading: false
              apex_config:
                chart:
                  height: 250px
                grid:
                  show: true
                  strokeDashArray: 0
                  borderColor: '#444444'
                  position: back
                  xaxis:
                    lines:
                      show: true
                  yaxis:
                    lines:
                      show: true
                yaxis:
                  forceNiceScale: true
                xaxis:
                  type: datetime
                  axisTicks:
                    show: true
                  tickAmount: 6
                  labels:
                    format: HH:mm
                  lines:
                    show: true
                fill:
                  type: gradient
                  gradient:
                    type: vertical
                    shade: dark
                    stops:
                      - 0
                      - 90
                    opacityFrom:
                      - 1
                      - 0.2
                    opacityTo:
                      - 0.2
                      - 1
              series:
                - entity: sensor.internet_speed_in1
                  color: var(--green1)
                - entity: sensor.internet_speed_out1
                  color: var(--green4)
                  invert: true
                - entity: input_number.zero_value
              all_series_config:
                stroke_width: 1
                type: area
Hope this helps to start…
This is a cool option ).
Sad that “mini-graph-card” does not have it & users have to use card-mod to achieve same.
Hi @mirekmal,
The information of the access point shown just above the Wifi throughput, is that a custom card or did you use cardmod?
All the cards are standard available cards (text-diver, markdown, apex chart) just put together into vertical stack. Here is full card code for one device:
type: custom:vertical-stack-in-card
cards:
  - type: custom:text-divider-row
    text: AP-GROUND
  - type: markdown
    content: >
      <ha-icon icon="mdi:information-variant"></ha-icon> Mesh Node: {{
      states('sensor.draytek_ap_g_model') }}
      <ha-icon icon="mdi:alert-outline"></ha-icon> FW Ver: {{
      states('sensor.draytek_ap_g_firmware') }}
      <ha-icon icon="mdi:clock-check-outline"></ha-icon> Uptime: {{
      states('sensor.draytek_ap_g_uptime') }}
    text: WI-FI Throughput
    update_interval: 5s
    graph_span: 5m
    show:
      loading: false
    apex_config:
      chart:
        height: 250px
      grid:
        show: true
        strokeDashArray: 0
        position: back
        xaxis:
          lines:
            show: true
        yaxis:
          lines:
            show: true
      yaxis:
      xaxis:
        type: datetime
        axisTicks:
          show: true
        tickAmount: 6
        labels:
          format: HH:mm
        lines:
          show: true
      fill:
        type: gradient
        gradient:
          type: vertical
          shade: dark
          stops:
            - 0
            - 90
          opacityFrom:
            - 1
            - 0.2
          opacityTo:
            - 0.2
            - 1
    series:
      - entity: sensor.lan_speed_ap_g_in
        color: var(--pink1)
      - entity: sensor.lan_speed_ap_g_out
        color: var(--pink3)
        invert: true
        color: var(--pink3)
    all_series_config:
      stroke_width: 1.5
      type: area
Tricky part are actual throughput sensors and device info - for all om my devices I use SNPM monitoring to get this data.
Thanks, this looks great!
I did not find some properties in the documentation, for example “xaxis”… when they are deleted, at first glance nothing changes…
update_interval: 5s
header:
  show: true
  title: Synology Network
graph_span: 6h
show:
  loading: false
apex_config:
  chart:
    height: 250px
  grid:
    show: true
    strokeDashArray: 0
    position: back
    xaxis:
      lines:
        show: true
    yaxis:
      lines:
        show: true
  yaxis:
series:
  - entity: sensor.synologynas_download_throughput
    color: '426F2A'
  - entity: sensor.synologynas_upload_throughput
    color: '892937'
    invert: true
all_series_config:
  stroke_width: 2
  type: area
apexchart-card implements full apex graphics library that is very extensive. Not everything is documented in card documentation. For more advanced functions you can refer to official apex documentation, where you can find tons of additional settings. In particular option you refers to is causing vertical lines (for xaxis) to be shown, but true is also default value. If you change this to false you will see the difference. So it here probably as remnant from the time I created this chart and was playinf with different settings.
I love your network monitoring dashboard cards!
I have something similar, just a little more basic (using snmp with mini chart cards and sensor groups) and would like to enhance mine with some of your design.
However, what is the purpose of the ‘- entity: input_number.zero_value’ and can I see your sensor and template config for this?
Well, I just use it to anchow y-scale to zero values. I noticed that if there is no zero value in the dataset, apex chart has tendency to shift the scale by fraction of unit. Also this gives a solid line at zero value for reference.
Nice design!
Would you please also share the code for the header card’s?
(WAN, Devices, ADGUARD)
Here it is
WAN:
cards:
  - type: custom:vertical-stack-in-card
    horizontal: false
    cards:
        text: WAN
        horizontal: true
        cards:
          - type: custom:button-card
            entity: sensor.bandwidth_utilization
            icon: mdi:web
            show_name: true
            show_state: true
            state_display: |
                if (states['sensor.snmp_wan1_status'].state == 1 )
                  return states['sensor.bandwidth_utilization'].state+"%";
                else
                  return "N/C";
            card_size: 7
            label: |
                  return states['sensor.myip'].state;
                else
                  return "DOWN";
            show_label: true
            styles:
              grid:
                - grid-template-areas: "\"i\" \"s\" \"l\" \"n\""
                - grid-template-columns: 1fr
                - grid-template-rows: 48px 48px 32px 48px
              name:
                - font-size: 13px
              state:
                - font-size: 28px
                - color: |
                        return "var(--ok-text)";
                      else
                        return "var(--alert-text)";
              label:
                - font-size: 16px
                - color: |
                      if (states['sensor.myip'].state == states['sensor.mirekmal_com'].state & states['sensor.myip'].state == states['sensor.mirekmal_homeserver_com'].state & states['sensor.myip'].state == states['sensor.mirekmal_dyndns_org'].state)
                        return "var(--dimmed-text)";
            entity: sensor.mirekmal_dyndns_org
            icon: |
                if (states['sensor.snmp_vpn_status'].state >= 1 )
                  return "mdi:shield-link-variant-outline";
                else
                  return "mdi:shield-off-outline";
            show_name: true
            show_state: true
            state_display: |
                  return states['sensor.bandwidth_utilization_vpn'].state+"%";
                else
                  return "N/C";
            card_size: 7
            label: |
                  return states['sensor.snmp_vpn_ip'].state;
                else
                  return "DOWN";
            show_label: true
            styles:
              grid:
              name:
                - font-size: 13px
              state:
                - font-size: 28px
                - color: |
                      else
              label:
                - font-size: 16px
            entity: sensor.mirekmal_vpn_ddns_net
            icon: |
                if (states['sensor.snmp_lte_status'].state == 1 )
                  return "mdi:signal";
                else
                  return "mdi:signal-off";
            show_name: true
            show_state: true
            state_display: |
                  return "OK";
                else
                  return "N/C";
            card_size: 7
            label: |
                  return states['sensor.mirekmal_lte_dyndns_org'].state;
                else
                  return "DOWN";
            show_label: true
            styles:
              grid:
              name:
                - font-size: 13px
              state:
                - font-size: 28px
                - color: |
                      else
                        return "var(--warning-text)";
              label:
                - font-size: 16px
                - color: |
                      else
DEVICES:
cards:
    text: DEVICES
    cards:
        entity: sensor.devices_all_count
        icon: mdi:check-network-outline
        show_name: true
        show_state: true
        state_display: |
            return states['sensor.fing_count_wired_devices_up'].state
        card_size: 7
        label: |
            return states['sensor.fing_count_wired_devices'].state
        show_label: true
        styles:
          grid:
          name:
            - font-size: 13px
          state:
            - font-size: 28px
            - color: var(--ok-text)
          label:
            - font-size: 16px
        entity: sensor.devices_wifi_count
        icon: mdi:access-point-network
        show_name: true
        show_state: true
        state_display: |
            return states['sensor.fing_count_wireless_devices_up'].state
        card_size: 7
        label: |
            return states['sensor.fing_count_wireless_devices'].state
        show_label: true
        styles:
          grid:
          name:
            - font-size: 13px
          state:
            - font-size: 28px
          label:
            - font-size: 16px
        entity: sensor.devices_guest_count
        icon: mdi:help-network-outline
        show_name: true
        show_state: true
        state_display: |
            return states['sensor.fing_count_guest_devices_up'].state
        card_size: 7
        label: |
            return states['sensor.fing_count_guest_devices'].state
        show_label: true
        styles:
          grid:
          name:
            - font-size: 13px
          state:
            - font-size: 28px
          label:
            - font-size: 16px
ADGUARD:
cards:
    cards:
      - text: ADGUARD
      - cards:
          - entity: switch.adguard_home_filtering
            icon: mdi:shield-check
          - entity: switch.adguard_home_parental_control
            icon: mdi:shield-account
          - entity: switch.adguard_home_protection
            icon: mdi:shield-bug
          - entity: switch.adguard_home_safe_browsing
            icon: mdi:shield-star
          - entity: switch.adguard_home_safe_search
            icon: mdi:shield-search
        horizontal: true
  - cards:
      - align_icon: left
        animate: false
        entities:
          - entity: sensor.adguard_home_dns_queries
            index: 0
        font_size: 50
        hour24: true
        hours_to_show: 24
        points_per_hour: 1
        smoothing: false
        line_color: var(--greenish)
        line_width: 3
        height: 150
        show:
          extrema: false
          fill: fade
          icon: false
        type: custom:mini-graph-card
      - align_icon: left
        animate: false
        entities:
          - entity: sensor.adguard_home_dns_queries_blocked
            index: 0
        font_size: 50
        hour24: true
        hours_to_show: 24
        points_per_hour: 1
        smoothing: false
        line_color: var(--cyanish)
        line_width: 3
        height: 150
        show:
          extrema: false
          fill: fade
          icon: false
      - align_icon: left
        animate: false
        entities:
          - entity: sensor.adguard_home_average_processing_speed
            index: 0
        font_size: 50
        hour24: true
        hours_to_show: 24
        points_per_hour: 1
        smoothing: false
        line_color: var(--light-magenta)
        line_width: 3
        height: 150
        show:
          extrema: false
          fill: fade
          icon: false
    type: horizontal-stack
card_mod:
  style: |
    position: top
Bear in mind lots of custom sensors (SNMP, RESTfull,) to get required data from router or fingbox…
Thank you man for sharing this.
Seriously, thank you bunches for sharing this. I absolutely love the layout you have. For now I’m looking to just pull the send/receive from my FIOS router, but am having one heck of a time getting the apexchart to go full width. Any thoughts? I’ve added my current dashboard code below.
  - title: Home
    sections:
      - type: grid
        cards:
            update_interval: 5s
            graph_span: 5m
            show:
              loading: false
            apex_config:
              chart:
                height: 250px
                redrawOnParentResize: true
                redrawOnWindowResize: true
              grid:
                show: true
                strokeDashArray: 0
                position: back
                xaxis:
                  lines:
                    show: true
                yaxis:
                  lines:
                    show: true
              yaxis:
              xaxis:
                type: datetime
                axisTicks:
                  show: true
                tickAmount: 6
                labels:
                  format: HH:mm
                lines:
                  show: true
              fill:
                type: gradient
                gradient:
                  type: vertical
                  shade: dark
                  stops:
                    - 0
                    - 90
                  opacityFrom:
                    - 1
                    - 0.2
                  opacityTo:
                    - 0.2
                    - 1
            series:
              - entity: sensor.fios_router_kib_s_received
              - entity: sensor.fios_router_kib_s_sent
                invert: true
                color: green
            all_series_config:
              stroke_width: 1
              type: area
        column_span: 4
For those that need it or are having similar issues and feeling frustrated, after several hours I figured it out. I had to nest the card into a horizontal-stack card. Code below for reference.
  - title: Network
    sections:
      - type: grid
        cards:
          - type: horizontal-stack
            cards:
                update_interval: 5s
                graph_span: 1h
                show:
                  loading: false
                apex_config:
                  chart:
                    height: 250px
                  grid:
                    show: true
                    strokeDashArray: 0
                    position: back
                    xaxis:
                      lines:
                        show: true
                    yaxis:
                      lines:
                        show: true
                  yaxis:
                  xaxis:
                    type: datetime
                    axisTicks:
                      show: true
                    tickAmount: 15
                    labels:
                      format: HH:mm
                    lines:
                      show: true
                  fill:
                    type: gradient
                    gradient:
                      type: vertical
                      shade: dark
                      stops:
                        - 0
                        - 90
                      opacityFrom:
                        - 1
                        - 0.2
                      opacityTo:
                        - 0.2
                        - 1
                series:
                    color: green
                    color: green
                    invert: true
                    color: darkgreen
                all_series_config:
                  stroke_width: 1
                  type: area
            grid_options:
              columns: full
              rows: auto
        column_span: 4
    type: sections
    max_columns: 4
    cards: []
I try to get all the sensors form my Unifi components. But it’s hard because there are no documented MIBs for the Unifi components. Found only two files for the access points. Can you help me and post the sensor configuration?
Not to put a plug out there, but for people that aren’t using Fing but have Verizon FiOS, I’ve made a custom HACS integration that will collect the data on the network usage (in concert to the normal UPnP/IGD integration for WAN speed) and devices connected to add value for you! It can be found at GitHub - skircr115/ha-verizonFiOS: Verizon FiOS Router HACS Integration
