How to make a Shelly 1 plus have a momentary button and not a switch
Hi All,
I am very, very new to HA.
I have a Shelly 1 plus that I use for my garage door. On the Shelly app it is a momentary button but on HA it is a switch. I have been searching to try and find out how I change this on HA to a momentary button.
If anyone knows can they describe the explanation as simply as possible. Im still very new and im slowly picking up the lingo and how the program works.
Cheers
You could create a template button:
# configuration.yaml
template:
  - button:
      - name: Garage Door
        icon: "mdi:garage"
        press:
          - service: switch.turn_on
              entity_id: switch.your_shelly_switch_here
          - delay: 1
          - service: switch.turn_off
However you would be better off with a template cover, especially if you have a sensor that tells you if the door is open or closed:
cover:
    covers:
      garage_door:
        device_class: garage
        friendly_name: "Garage Door"
        value_template: "{{ states('sensor.garage_door')|float > 0 }}"
        open_cover:
          - delay: 1
        close_cover:
          - delay: 1
        stop_cover:
          - delay: 1
Thanks Tom. Ill give this a go tonight when im home. i dont want to open and close the garage when Im not there :grinning:
