How to make a switch with two scripts
Hey,
I’ve only just started using Home Assistant and I need some help.
I have a ceiling fan that I’m trying to control using a Logitech Harmony. I did get it working using these scripts
to turn fan on:
ceiling_fan_fan_medium:
  alias: Fan Medium
  sequence:
  - service: remote.send_command
      entity_id: remote.harmony_hub
      command:
      - Fan Medium
      device: Ceiling Fan
to turn fan off:
ceiling_fan_fan_off:
  alias: Fan Off
  sequence:
      command:
      - Fan Off
      device: Ceiling Fan
But it’s not how I want it. It looks clean in the Home Assistant UI
but when I use Homekit it looks like a mess.
I was wondering if anyone could help me turn those two scripts into one on and off switch for homekit. I’ve tried using ChatGPT to help me but it hasn’t worked lol.
Thanks.
It never does.
Assuming the command accepts a template:
  • Create a Toggle Helper (input_boolean), call it Fan.
  • Create an automation (can do it in the UI if you prefer, but you’ll have to Edit as YAML for the template):
  - platform: state
    entity_id: input_boolean.fan
      command:
      - "{{ {'on': 'Fan Medium', 'off': 'Fan Off'}[trigger.to_state.state] }}"
      device: Ceiling Fan
You can then put that toggle in the dashboard.
If you didn’t want to use a template, you can put Choose logic in the action instead to achieve the same thing.
There’s an easier solution:
I got it working with this
- alias: Ceiling Fan State Changed
    platform: state
    entity_id: input_boolean.ceiling_fan_state
    - choose:
      - conditions:
          - condition: state
            state: 'on'
        sequence:
              command: Fan Medium
              device: Ceiling Fan
      - conditions:
          - condition: state
            state: 'off'
        sequence:
              command: Fan Off
              device: Ceiling Fan
Thank you
The best way to represent a fan is not a switch, not a script or input select, but …ehhh… a fan :wink:
