JerryY
(Jerry)
1
I am trying to make a sensor that I can use in an automation. I got the code from Home Assistant - Alert.
I used the Developer section to make sure I got the parameters correct.
Here is my code:
binary_sensor:
sensors:
tilt_battery_low:
value_template: "{{ state_attr('zwave.ecolink_garage_door_tilt_sensor', 'battery_level') < 50 }}"
friendly_name: "Tilt battery is low"
I get an error in the log stating there is an error in this code. The error text doesn’t provide any clue to me, other than something is wrong.
I appreciate any help!
Please try this as template.
{{ state_attr('zwave.ecolink_garage_door_tilt_sensor', 'battery_level') | int < 50 }}
This makes the state_attr a int to compare with 50
tom_l
3
The important thing to know is that the state of entities in Home Assistant are always strings and you can’t compare a string to a number.
So before doing the comparison you must convert the string to a number. We have two filters to do this:
| int
converts the string to an integer (no decimal/fractional part), ('1.234' ) | int == 1
| float
converts the sting to a floating point number, (has a fractional part). ('1.234' ) | float == 1.234
Attributes of entities in Home Assistant recently obtained the ability to be more types than just string.
JerryY
(Jerry)
4
Thanks for the quick and perfect assistance! Converting to int did the trick!
