I have a wallmote quad that I try to add to my Home Assistant. I have followed the instructions here. When I click button 1 the wallmote flashes blue twice and red once and I see this in the log:
2019-12-11 20:48:00.569 Detail, Node004, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x04, 0x05, 0x5b, 0x03, 0x13, 0x00, 0x01, 0xbb
2019-12-11 20:48:00.569 Info, Node004, Received Central Scene set from node 4: scene id=1 in 0 seconds. Sending event notification.
2019-12-11 20:48:00.569 Detail, Node004, Initial read of value
2019-12-11 20:48:00.570 Detail, Node004, Notification: ValueChanged
I have set up an automation that triggers on event “zwave.scene_changed” with data:
I have tried both “zwave.aeon_labs_zw130_wallmote_quad” and the numeric id it has (4). But no difference. I don’t see any specific examples for the wallmote quad?
Doesn’t matter what the device is, if it sends a Central Scene message it will trigger a zwave.scene_activated event. The event always sets zwave entity, node id, scene id and scene data. The examples apply equally to all devices, what may be different is the scene IDs and data. You are using the correct values based on the logs scene id=1 in 0.
