How to make an automation that I only run manually from HA
as I understood from the help, triggers and conditions are not necessary, I create this one
- id: '6d4c566e-2362-4b6c-b821-aa83604e7c6f'
  alias: Movie
  actions:
  - action: light.turn_off
    metadata: {}
    data: {}
      entity_id: light.kabinet_stena
  mode: single
That is, I want the light to turn off when the automation is turned on.
Error:required key not provided @ data[‘triggers’]. Got None.
So I need a trigger ? how can I just start the automation from HA by switching the slider in the list where all automations are ?
Hi D,
You want a script, not an automation.
can you show me script with simple example with turn the light off ?
If you have a way of getting the state of the media player into HA use that as a trigger instead.
its not help
I just copy past script from help and have errors that i dont understand
There is a script UI editor. It will help you write a script.
Open your Home Assistant instance and show your scripts.
