How to make climate. entity for Better thermostat? ESP32
Hi
I wanna make climate entity for my 4ch ESP32 relay board and wanna use better thermostat integration for controlling temperature in my rooms.
But… If I make “Generic thermostat” to HA Yaml, it duplicates my climate entity when I use Better thermostat.
So how I can get .climate entity for my esp32 board relays without temperature sensor etc.
Hi Aa-Koo,
You add a temperature sensor. It should probably be a separate device that is connected thru Home Assistant. But you cannot have a thermostat or climate entity of any kind if it does not have the temperature information.
