As for Errors, this is the Core log since last reboot (has been more Errors before)
2022-03-10 22:49:22 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2022-03-10 22:49:22 DEBUG (MainThread) [zigpy_znp.api] Received command: SYS.Ping.Rsp(Capabilities=<MTCapabilities.APP_CNF|GP|UTIL|ZDO|AF|SYS: 1625>)
2022-03-10 22:53:02 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-10 23:22:17 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x6DF4:11:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>')]
2022-03-10 23:22:17 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x6DF4:11:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>')]
2022-03-10 23:22:38 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x6246
2022-03-10 23:41:16 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-10 23:41:34 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x6246
2022-03-10 23:42:50 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x568C
2022-03-10 23:45:36 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x568C
2022-03-10 23:56:14 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x568C
2022-03-11 00:26:30 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 00:27:33 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 01:00:34 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2B1
2022-03-11 01:07:00 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x59A8
2022-03-11 02:23:23 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x6246
2022-03-11 02:32:38 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.9/site-packages/zigpy/topology.py", line 52, in scan_loop
await self.scan()
File "/usr/local/lib/python3.9/site-packages/zigpy/topology.py", line 63, in scan
await self._scan_task
File "/usr/local/lib/python3.9/site-packages/zigpy/topology.py", line 86, in _scan
await device.neighbors.scan()
File "/usr/local/lib/python3.9/site-packages/zigpy/neighbor.py", line 94, in scan
return await self._scan()
File "/usr/local/lib/python3.9/site-packages/zigpy/neighbor.py", line 105, in _scan
status, rsp = await self._device.zdo.Mgmt_Lqi_req(idx, tries=3, delay=1)
File "/usr/local/lib/python3.9/site-packages/zigpy/util.py", line 110, in retry
r = await func()
File "/usr/local/lib/python3.9/site-packages/zigpy/device.py", line 265, in request
result, msg = await self._application.request(
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 439, in request
return await self._send_request(
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 1401, in _send_request
response = await self._send_request_raw(
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 1279, in _send_request_raw
response = await self._znp.request(
AttributeError: 'NoneType' object has no attribute 'request'
2022-03-11 02:42:02 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 02:56:56 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x568C
2022-03-11 03:24:30 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x6DF4:11:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2022-03-11 03:24:31 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x6DF4:11:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>')]
2022-03-11 04:01:16 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2B1
2022-03-11 04:07:43 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x59A8
2022-03-11 05:24:09 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x6246
2022-03-11 05:42:48 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 05:57:14 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x568C
2022-03-11 06:22:20 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 06:23:29 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 06:35:59 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 06:37:04 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 06:42:09 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x59A8
2022-03-11 06:53:31 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x59A8
2022-03-11 06:55:46 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x6246
2022-03-11 06:57:33 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x568C
2022-03-11 07:00:32 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 07:01:38 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 07:01:59 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2B1
2022-03-11 07:04:38 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 07:06:49 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 07:08:27 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x59A8
2022-03-11 07:21:31 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 07:23:43 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 07:25:22 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x6DF4:11:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>')]
2022-03-11 07:25:22 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x6DF4:11:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_NO_ROUTE: 205>')]
2022-03-11 07:57:32 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 07:58:51 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 08:24:56 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x6246
2022-03-11 08:43:30 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 08:54:08 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x6246
2022-03-11 08:54:15 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x6246
2022-03-11 08:57:51 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x568C
2022-03-11 09:09:19 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 09:10:24 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 10:02:41 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2B1
2022-03-11 10:09:07 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0x59A8
2022-03-11 10:57:01 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 10:59:09 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
2022-03-11 11:04:03 WARNING (MainThread) [zigpy_znp.zigbee.application] Received an AF message from an unknown device: 0xF2CD
I suspect it to be a problem with ram since it especially occurs when I try to install additional Addons (already have adguard, Vaultwarden, Letsencrypt and VS Code Server installed and running).
Maybe I’ll try to install it onto an my old Thinkpad to see if it is more stable and treat myself to a rpi 4 with 4 or 8 gigabytes of ram once those are obtainable and affordable again.
Oh and btw I have ZHA with a SONOFF USB Zigbee Dongle.
