Hi everyone, I need help creating a led chase effect with 4 lights that runs without stopping, can you guys help with the yaml for that, each LED should use it’s own pin.
Something like this bellow…
Did you get one LED hooked up and switchable?
I would have thought you would just do that 4 times.
Then maybe set up another switch with say a repeat
or while action, with delays that cycle through the LEDs.
Hi Mahko, my problem isn’t really creating the the effect, it is how to make it repeat infinitely.
You can use the interval:
component to achieve infinitely
light:
- platform: binary
output: led_1_o
- platform: binary
output: led_2_o
- platform: binary
output: led_3_o
- platform: binary
output: led_4_o
output:
- id: led_1_o
platform: gpio
pin: GPIO16
- id: led_2_o
platform: gpio
pin: GPIO17
- id: led_3_o
platform: gpio
pin: GPIO18
- id: led_4_o
platform: gpio
pin: GPIO19
interval:
- interval: 200ms
then:
- lambda: !lambda |-
static int led_nr=1;
switch (led_nr) {
case 1:
auto call = id(led_1).turn_on();
call.perform();
call = id(led_4).turn_off();
call.perform();
break;
case 2:
auto call = id(led_2).turn_on();
call.perform();
call = id(led_1).turn_off();
call.perform();
break;
case 3:
auto call = id(led_3).turn_on();
call.perform();
call = id(led_2).turn_off();
call.perform();
break;
case 4:
auto call = id(led_4).turn_on();
call.perform();
call = id(led_3).turn_off();
call.perform();
break;
default:
break;
led_nr += 1;
if (led_nr == 5) {
led_nr = 1;
Thank you that helped a lot, I am using this to make a stepper run without stopping,
Do you know how to achieve the same effect but using the stepper component?
No, I never used that component. As far as I know that component is used to control a stepper motor DRIVER and not different output pins.
