Hi All, I have a couple of old ceiling fans that I’m hoping to make smart.
Looks like this with the cover removed - https://i.imgur.com/budCYS8.jpg
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
What country are you in? (device availability varies by country)
What kind of fan? (you’ll likely replace that switch /controller device in its entirety)
Do you currently use any other devices that are ZWave, Zigbee or Wi-Fi for lighting control?
Thanks for the reply @NathanCu
Located in Australia
Happy to replace the fan control dial components, full control of the fan is via the dial.
There is a 1 light on the fan but it switched elsewhere (currently has a hue bulb, so it’s “always on” at the switch.
Fan speeds 3/4/5 are the main ones used, 1/2 are largely useless.
I have a stack of zigbee devices (via Z2M) already, open to Shelly/other home assistant integrated devices.
Items will be installed via an electrician due to the rules in AU, just want to make sure I’m looking in the right spot/providing the right hardware suggestions that talk to Home Assistant.
