How to make Samba Shares read-only
I have successfully setup Samba using the add-on to expose the usual shares.
I wish to backup the files in the shares across the network using my existing backup infrastructure.
For security reasons i’d prefer these shares to be read-only and accessed by a “backup” user.
Is there a way to configure this using the existing add-on settings or am I better off not using the add-on and configuring Samba manually. I realise I could probably use the add-on to initially setup the shares and then make changes to the settings, but I’d be worried those setting would then change as updates are applied.
Best regards,
Alex
I have the same question. It seems like this would be pretty simple to add as a configuration option in the add-on
