How to make the automation shorter?
I have two automation like this:
- alias: switch_toggle_lamp_gostinaia
  initial_state: true
  - platform: event
    event_type: xiaomi_aqara.cube_action
    event_data:
      entity_id: binary_sensor.cube_158dXXXXXXXXX
      action_type: shake_air
  condition:
    - condition: time
      after: '07:00:00'
      before: '00:00:00'
    - service: light.toggle
        entity_id: light.gostinaia
        brightness_pct: 100
        color_temp: 200
  initial_state: true
  - platform: event
    event_data:
  condition:
    - condition: time
      after: '00:00:00'
      before: '07:00:00'
        brightness_pct: 40
        color_name: blue
How can I make the automation shorter, check the time directly in the action section, and change the brightness and color of my lamp there. I am just starting to master HA and still do not know everything, I would be grateful if you would help me.
The following example is based on the choose feature which is described here: Choose a Group of Actions
  - platform: event
    event_data:
  - choose:
    - conditions: "{{ 0 <= now().hour <= 7 }}"
      sequence:
          brightness_pct: 40
          color_name: blue
    default:
        brightness_pct: 100
        color_temp: 200
thank you very much you helped me a lot
You’re welcome!
Please consider marking my post (above) with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has an accepted solution. It helps users find answers to similar questions.
