How to make the sum of Channel A+B+C in Lovelace Mini Graph Card - Shelly 3EM
I want to make a graph in Lovelace of the sum of all 3 signals.
Current code:
type: custom:mini-graph-card
entities:
  - sensor.shelly_3em_channel_a_power
  - sensor.shelly_3em_channel_b_power
  - sensor.shelly_3em_channel_c_power
height: 300
line_width: 1
show:
  labels: true
  average: true
  extrema: true
hours_to_show: 2
points_per_hour: 60
panel: true
With panel: true
This is not possible in the mini-graph card. Either create a template sensor that sums your sensors and graph that or use the Apexchats card that does have this functionality.
Thanks for your advice.
The solution:
With File Editor open the file configuration.yaml and write following code:
template:
  - sensor:
      - name: Energy_total
        unit_of_measurement: kWh
        state: "{{ (states('sensor.shelly_3em_channel_a_power')|float + states('sensor.shelly_3em_channel_b_power')|float + states('sensor.shelly_3em_channel_c_power')|float) }}"
        device_class: energy
Save, and reboot.
Then search for sensor.energy_total, this is your summation of all 3 sensors.
The Code will be then for mini-graph card:
entities:
  - sensor.energy_total
height: 300
line_width: 1
show:
  labels: true
  average: true
  extrema: true
hours_to_show: 2
points_per_hour: 600
panel: true
With panel: true
DONE
You may want to add an availability template to your total sensor so that it only reports values when all the sensors are available. Also you have to define default values for the float filters or the template sensor may fail during startup.
template:
  - sensor:
        state: "{{ states('sensor.shelly_3em_channel_a_power')|float(0) + states('sensor.shelly_3em_channel_b_power')|float(0) + states('sensor.shelly_3em_channel_c_power')|float(0) }}"
        availability: >
          {{ states('sensor.shelly_3em_channel_a_power')|is_number and
             states('sensor.shelly_3em_channel_b_power')|is_number and
             states('sensor.shelly_3em_channel_c_power')|is_number }}
Great. Thanks a lot! :slight_smile:
I made an error in the code.
It must be:
unit_of_measurement: W
NOT
kWh
I am trying to implement this as well (newbie), but have a few questions:
  1. shouldn’t the device class be “power”?
  2. It doesn’t work for me, value is 0W
template:
  - sensor:
      - name: power_total
        availability: >
        device_class: power
Thanks :slight_smile:
Hi Markus hope this helps:
This is my final setting that works:
configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
template:
  - sensor:
      - name: energy_total
        availability: "{{ states('sensor.shelly_3em_channel_a_power')|is_number and states('sensor.shelly_3em_channel_b_power')|is_number and     states('sensor.shelly_3em_channel_c_power')|is_number }}"
  - sensor:
      - name: energy_null
        state: "{{ 0 }}"
mini-graph-card
name: Summe Leistung, 2h [W]
entities:
  - sensor.energy_null
height: 300
line_width: 1
show:
  labels: true
  average: true
  extrema: true
hours_to_show: 2
points_per_hour: 60
panel: true
With panel: true
As Markus said, this is wrong:
It should be:
 device_class: power
Power is measured in W or kW.
Energy is measured in Wh, or kWh.
Same for this:
  - sensor:
      - name: energy_null
        state: "{{ 0 }}"
