I have bought a ZB-GW03 hub and added this to HA via the Mosquitto broker Add-on. I have configured Mosquitto so that I got the Tasmota integration. In the integration I do see entities but these have all status unknown, see picture. Further I have paired three devices to the hub; one sensor and two power plugs. These are visible on the web-portal of the ZB-GW03 hub, see picture. However I can’t control these plugs in this portal. My problem is that the paired devices does not show up in the HA Tasmota integration and I can’t find them in HA somewhere else either. Is there any advise how I can get this work?
Is there an image missing? I can’t see any “unknown” devices.
Have a read through this thread. You might be skipping a few steps, so make sure you follow the instructions carefully.
You need to manually create MQTT entities in configuration.yaml,
See
and
Thanks Francis, these are useful suggestions. Now I have working via the console of the zigbee bridge to turn on and off the plug via:
ZbSend { “device”:“0x57XX”, “send”:{“Power”:“1”} }
ZbSend { “device”:“0x57XX”, “send”:{“Power”:“0”} }
However how can I create a button in HA to integrate this plug via these commands? So far I have not understood this via the ‘Instructions on how to setup MQTT within Home Assistant’. Can you point me in the right direction?
I have updated HA to 2024.3.3 which was needed to be able to use mqtt in the configuration.yaml config file. However I have tried different templates but unfortunately I still not managed to add a switch symbol in HA which I can use to toggle my power-plug with device ID:“0x57XX” to turn this power plug on and off, what I can manage via the console of the Tasmota brige with
install mqtt-explorer ( https://mqtt-explorer.com/ ) and show exactly what topic and message is received
(text, not a screenshot, that is to difficult to type over without mistakes)
Hi, hereby:
10.10.10.209
▼tele
▼tasmota_2D3B58
LWT = Online
SENSOR = {“ZbReceived”:{“0x57C5”:{“Device”:“0x57C5”,“CurrentSummationDelivered”:“0x000000000001”,“RMSVoltage”:231,“RMSCurrent”:0,“ActivePower”:0,“Endpoint”:1,“LinkQuality”:42}}}
▼tasmota
▼discovery
▼08D1F92D3B58
config = {“ip”:“10.10.10.203”,“dn”:“Ali-bridge”,“fn”:[“Ali-bridge”,null,null,null,null,null,null,null],“hn”:“tasmota-2D3B58-7000-eth”,“mac”:“08D1F92D3B58”,“md”:“ZB-GW03”,“ty”:0,“if”:0,“ofln”:“Offline”,“onln”:“Online”,“state”:[“OFF”,“ON”,“TOGGLE”,“HOLD”],“sw”:“13.2.0”,“t”:“tasmota_2D3B58”,“ft”:“%prefix%/%topic%/”,“tp”:[“cmnd”,“stat”,“tele”],“rl”:[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0…
sensors = {“sn”:{“Time”:“1970-01-02T03:42:50”},“ver”:1}
▼$SYS
▼broker
version = mosquitto version 2.0.18
uptime = 748 seconds
▼clients
total = 3
inactive = 0
disconnected = 0
active = 3
connected = 3
expired = 0
maximum = 3
▼load
▼messages
▼received
1min = 4.32
5min = 4.46
15min = 2.87
▼sent
1min = 38.95
5min = 24.55
15min = 11.22
▼publish
▼dropped
1min = 0.00
5min = 0.00
15min = 0.00
▼received
1min = 0.80
5min = 0.92
15min = 0.77
▼sent
1min = 29.50
5min = 18.49
15min = 8.10
▼bytes
▼received
1min = 157.08
5min = 191.34
15min = 153.48
▼sent
1min = 929.31
5min = 771.60
15min = 404.42
▼sockets
1min = 0.13
5min = 0.29
15min = 0.24
▼connections
1min = 0.13
5min = 0.27
15min = 0.20
▼messages
stored = 56
received = 66
sent = 547
▼store
▼messages
count = 56
bytes = 1130
▼subscriptions
count = 15
▼shared_subscriptions
count = 0
▼retained messages
count = 56
▼heap
current = 74656
maximum = 75792
▼publish
▼messages
dropped = 0
received = 19
sent = 501
▼bytes
received = 2549
sent = 6087
▼bytes
received = 4013
sent =
mqtt:
switch:
- unique_id: "996080f7-aaa9-4850-baed-31c9298d6956"
state_topic: "tele/tasmota_2D3B58/SENSOR"
value_template: "{{ value_json['ZbReceived']['0x57C5']['Power'] }}"
state_on: 1
state_off: 0
command_topic: "cmnd/tasmota_2D3B58/ZbSend"
payload_on: '{"device":"0x57C5","send":{"Power":"On"} }'
payload_off: '{"device":"0x57C5","send":{"Power":"Off"} }'
availability_topic: "tele/ttasmota_2D3B58/LWT"
payload_available: "Online"
payload_not_available: "Offline"
optimistic: false
qos: 0
Thanks! I paste this config in the configuration.yaml file and I got the switch available in the entities. However it is in the state “Unavailable” and greyed out. However it is connected and still reple via the Tasmota console:
15:14:29.329 CMD: ZbSend { “device”:“0x57C5”, “send”:{“Power”:“1”} }
15:14:29.335 MQT: stat/tasmota_2D3B58/RESULT = {“ZbSend”:“Done”}
15:14:30.230 MQT: tele/tasmota_2D3B58/SENSOR = {“ZbReceived”:{“0x57C5”:{“Device”:“0x57C5”,“Power”:1,“Endpoint”:1,“LinkQuality”:68}}}
I saw the error, one t too many
should be
"tele/tasmota_2D3B58/LWT"
Hello, this has done the job indeed! Thanks for this. It is still reasonable complicated for me.
I went further since I have got a second power plug and a humidity /temperature sensor. I used the following yaml config:
mqtt:
switch:
- unique_id: “996080f7-aaa9-4850-baed-31c9298d6956”
state_topic: “tele/tasmota_2D3B58/SENSOR”
value_template: “{{ value_json[‘ZbReceived’][‘0x57C5’][‘Power’] }}”
state_on: 1
state_off: 0
command_topic: “cmnd/tasmota_2D3B58/ZbSend”
payload_on: ‘{“device”:“0x57C5”,“send”:{“Power”:“On”} }’
payload_off: ‘{“device”:“0x57C5”,“send”:{“Power”:“Off”} }’
availability_topic: “tele/tasmota_2D3B58/LWT”
payload_available: “Online”
payload_not_available: “Offline”
optimistic: false
qos: 0
switch:
- unique_id: “996080f7-aaa9-4850-baed-31c9298d6957”
value_template: “{{ value_json[‘ZbReceived’][‘0x5796’][‘Power’] }}”
state_on: 1
state_off: 0
payload_on: ‘{“device”:“0x5796”,“send”:{“Power”:“On”} }’
payload_off: ‘{“device”:“0x5796”,“send”:{“Power”:“Off”} }’
optimistic: false
qos: 0
- unique_id: “996080f7-aaa9-4850-baed-31c9298d6958”
name: “Temperatuur Ali 1”
suggested_display_precision: 1
unit_of_measurement: “°C”
value_template: “{{ value_json[‘ZbReceived’][‘0xB064’][‘Temperature’] }}”
- unique_id: “996080f7-aaa9-4850-baed-31c9298d6959”
name: “Vocht Ali 1”
unit_of_measurement: “%”
value_template: “{{ value_json[‘ZbReceived’][‘0xB064’][‘Humidity’] }}”
Two problems:
-The first sensor entity Plug-Ali-1is not available anymore. I changed the device ID and I also added 1 to the unique ID. Is that not sufficient?
-I get empty charts with the humidity/temperature sensor “Temperatuur Ali 1” and “Vocht Ali 1”
From the Tasmota console I read:
18:58:21.447 MQT: tele/tasmota_2D3B58/SENSOR = {“ZbReceived”:{“0xB064”:{“Device”:“0xB064”,“Temperature”:17.5,“Humidity”:63.1,“Endpoint”:1,“LinkQuality”:14}}}
But using the command in this console
19:26:34.393 CMD: ZbReceived { “device”:“0x57C5”, “read”:{“Temperature”} }
I get
19:26:34.401 MQT: stat/tasmota_2D3B58/RESULT = {“Command”:“Unknown”}
Do i use wrong syntax here of is my method for these sensors wrong?
Please format your code
You can easily create unique id’s on this site
Because it is
mqtt:
switch
etc ...
- unique_id etc..
and not
mqtt:
switch:
- unique_id:
switch
- unique_id ..
same for sensor
- unique_id: "c727f4b5-1a14-440e-bd0b-52274dcfc4ff"
value_template: "{{ value_json['ZbReceived']['0x57C5']['Temperature'] }}"
availability_topic: "tele/tasmota_2D3B58/LWT"
qos: 0
device_class: "temperature"
unit_of_measurement: '°C'
- unique_id: "38a96f91-a393-4ba4-bcdd-189bcfb2f738"
name: “Vocht Ali 1”
value_template: "{{ value_json['ZbReceived']['0x57C5']['Humidity'] }}"
qos: 0
device_class: "humidity"
unit_of_measurement: '%'
Thanks again, this cleared up the disappeared power plug.
The sensors do also exist now, however the data is still unknow. For some reason the temperature and humidity variables does not reach the entity in HA.
By the way; do you use a generator for the unique id’s or do you extract these from somewhere?
I forgot to change 0x57C5 to 0xB064 in the sensors
I missed this device ID’s too, but corrected them now. Unfortunately still unknown data.
- unique_id: “c727f4b5-1a14-440e-bd0b-52274dcfc4ff”
qos: 0
device_class: “temperature”
unit_of_measurement: ‘°C’
name: “Vocht Ali 1”
value_template: "{{ value_json['ZbReceived']['0xB064']['Humidity'] }}"
qos: 0
I usually blow on them to get them to update
