I have a custom device that is running on a d1 mini. I have a PID Climate that is outputting to a slow pwm relay. I also have that relay set up as a switch. When the PID Climate is set to mode “OFF”, I’d like to be able to control the relay via the switch. However right now when I turn the switch on, it immediately turns off (I’m assuming it is from the PID climate). Any idea how to control the relay when the PID Climate is off? Thanks.
Instead of directly controlling the relay from your PID climate or switch, create a switch in between where you can control the switching behavior. One option is to add a binary sensor in between.
binary_sensor:
filters:
- lambda: return x || id(my_switch).state;
on_press:
then:
- switch.turn_on: climate_relay
on_release:
then:
- switch.turn_off: climate_relay
The filter evaluates the value against the state of your switch. When either is ON, will switch on the relay and only when both OFF then would switch off relay.
Setting binary sensor value from your climate and switch can be done with publish_state: (id(relay_state).publish_state(true);
Thanks for pointing me on the track. The PID Climate has to output to a float, in this case a slow pwm output. The on/off of the output turns a climate binary sensor on and off. There switch controlling the same output that isn’t tied to a GPIO. The “controlling” binary sensor checks the switch state and climate binary sensor, then turns the output on and off accordingly…pretty much just as you described. Here is my relevant code:
dallas:
- pin: D3
update_interval: 1s
# Individual sensors
- platform: dallas
address: 0x8203089779e2fd28
name: "Brew Kettle Temp"
output:
- platform: slow_pwm
period: 15s
turn_on_action:
- binary_sensor.template.publish:
state: ON
turn_off_action:
state: OFF
- platform: gpio
pin: D6
binary_sensor:
name: 'Mash Element Active'
lambda: |-
if (id(mash_switch).state || id(climate_relay_state).state) {
return true;
} else {
return false;
on_press:
then:
- output.turn_on: mash_relay
on_release:
then:
- output.turn_off: mash_relay
switch:
optimistic: True
climate:
- platform: pid
sensor: kettle_temp
default_target_temperature: 66.667°C
heat_output: mash_slow_pwm
control_parameters:
kp: 0.87308
ki: 0.00353
kd: 53.99995
output_averaging_samples: 5 # smooth the output over 5 samples
derivative_averaging_samples: 5 # smooth the derivative value over 10 samples
visual:
min_temperature: 60 °C
max_temperature: 72 °C
temperature_step: 0.1 °C
