I’m trying to mount a samba share on my Synology NAS to be used as a backup target.
I’m not able to do that, I’ve tried the following:
- Mounting on commandline ->succesfull, but of course, lost on restart of system)
- Adding to fstab -> gets lost / overwritten on restart
- Mounting in shell script and calling that from within HA with the shell-integration -> does not work, I do not understand why this did not work (possibly ‘strange-characters’ issue)
- Mounting by putting the mount command directly in shell-integration in configuration.yaml. I started of having issues with ‘strange-characters’ in my password. When I changed that it reported the
This is the command I use (change IP, username, password):
mount -t cifs //0.0.0.0/NetBackup NetBackup -o username=name,pass=password,vers=3.0
I tried replace the NetBackup target with (./NetBackup config/NetBackup and the full path in config folder and in the share folder.
Also tried this after successfully creating a folder in the config dir using a shell command.
I keep getting the message:
mounting //0.0.0.0/NetBackup on NetBackup failed: Resource busy
Anybody experience in this? How to solve this?
