How to match IEEE addresses in zigbee.db with entity IDs?
I’m trying to remove a zigbee light-bulb. I have the DB open and can see addresses and model numbers, but I have 5 of the same bulb. How do I match up the address with an entity ID?
You don’t need to edit the db anymore, you can use the command zha.remove
I usually cut power to the device and see which one shows up “offline” in the UI, but there might be a more elegant solution.
I was trying to use the zha.remove command but didn’t know how to match the address to a specific entity ID. I have several of the same lightbulb - I did end up just turn off the ones I wanted to remove on turning on the rest.
