i am seriously struggling with such “triviality” ie how to measure room temp/ humidity.
I used 4 different devices, and all are reporting different values … no idea why (See attached photo)
Any idea why these sensors produce such different values and how to read temp/humid correctly?
Thanks!
zwave philip pat02B:
25.31 Deg
61.15 %
zwave Eurotronic Air Quality Sensor Z-Wave Plus
25.1 Deg
43 % humid
It’s not very common for thermometers to be more accurate.
Since I work with food, quality and temperature I have access to a calibration thermometer, it costed about $1900 (US) and is sent on service once a yeat, it has a tolerance of 0.5 degrees Celsius.
What you are asking for is just not feasible for a device costing as little as they do.
One of the cheaper hygrometers we have at work has a tolerance of ±5%.
Devices aren’t very accurate.
ah i see, then how can one have properly measured temp at home and also set up system for a heating properly? 0.5-1C seems not that much …
but when u heat 22 or 23 its difference.
Well, the room temperature is also very different depending on the height you are measuring, the location (close to wall, close to window, close to heat source), if it’s windy/cold or if it’s sunny and hot.
So the temperature you measure at one side/height will not be the same as a different side of the room/height.
So? What is correct?
I believe you need to calibrate it with humans.
Set the temperature to something then see what it feels like and change it if needed.
Within a few days you will have calibrated all rooms.
Temperatures are very subjective. Set your thermostat to the temperature your family wife feels comfortable with. If the comfort is fine, it doesn’t matter if it says it is 22 or 24 or a number between 1 and 10.
i cant access esphome … weird… but it says …
The sht4x sensor platform allows you to use your SHT4X temperature and humidity sensor (datasheet, Adafruit) with ESPHome.
The I²C Bus is required to be set up in your configuration for this sensor to work.
For calibration, I used a simple thermometer. I left the sensor and thermometer together for a day or so, then started intermittently checking the readings. The sensors I was using were consistent in their errors, as far as I could see, so once I’d established what the error was, I created a secondary sensor that added or subtracted the error, for each device, and that’s worked for me. It helps that my partner hasn’t complained, so I must have done something right!
Use multiple sensors and stick them in the min_max integration. That’s how I do it - it also means I get the whole floor temperature rather than just a single room.
