How to Migrate from Ecobee Cloud Integration to Local HomeKit Controller
I am adding here to share my experience with setting up an Ecobee Thermostat but the main difference for me is my HA runs in a docker container.
In a docker container “being on the same network” is not trivial. The docker network is typically a 172.0.0.0/16 range and the host machine is sitting on the same range as your network router. The mDNS broadcasts from the HA container to auto-discover the thermostat do not make it to the router’s network where the thermostat lives.
To get around this the easiest method is to add network_mode: host to your compose config for HA. However I have many containers running and already configured a lot of integrations in HA using the docker domain names so i would have to reconfigure a lot of I change the network mode. I also have HA behind a reverse proxy so i want to continue to use the proxy to pass traffic to the HA container and dont want to change that.
So how do I get only mDNS discovery pings to get to my host machine’s network?
I used an mdns repeater aptly named mdns-repeater docker container found here. I then configured this docker container using the following compose settings:
  mdns-repeater:
    image: monstrenyatko/mdns-repeater:latest
    container_name: mdns-repeater
    restart: unless-stopped
    command: mdns-repeater-app -f br-77625678b050 eno1
    network_mode: "host"
The important part is configuring the command. The two parameters passed are the network interfaces I want this container to repeat. So br-77625678b050 is the docker network my HA lives on and eno1 is the network my host machine lives on.
You can find the host interface by:
  1. Run ifconfig on your host machine
  2. Find the ip range your host machine lives on
  3. Record the interface name
You can find the docker network interface by:
  1. Run docker network inspect <network-name> on your host machine
  2. Search for the Subnet range. It will look like:
 "Config": [
                    "Subnet": "172.18.0.0/16",
                    "Gateway": "172.18.0.1"
  1. Run ifconfig
  2. Search for what interface name matches the subnet range
Once you boot the container it will repeat the mDNS discovery from your HA container’s network to the host machine’s network. After this i was able to setup the Homekit Controller normally and the mDNS found me thermostat
One more thing! The pairing code for my thermostat was not in the format specified in the original post nor the documentation. It was simply 8 numbers with no hpyhens.
Thanks for posting this Homekit procedure as it worked perfect for me. The ecobee cloud update was always so delayed it was unusable for automations. Since I have 2 thermostats but only one furnace, I had struggled trying to get accurate runtimes since ecobee stats treat each thermostat as a separate entity. After using your procedure I set up an automation that would activate a virtual switch using as a trigger the status hvac_current action going from idle to heat for both thermostats. Created a second automation that triggers on ecobee going back to idle. The idle automation had a condition statement making sure both thermostats were in idle before toggling the switch to off.
At this point the virtual switch has the perfect run time statistics since it’s tracking both thermostats. I then created daily, weekly, monthly, and quarterly utility meter historical sensors so the stats are not gone after the standard 10 days I have within HA. I just completed all this but will need to see if the stats stay after 10 days but I have no reason to believe they won’t. I then replicated the above to track the central air system using “cooling” instead of “heating” havac action.
Thanks @automateit for the write-up, this is super helpful! I am considering buying an Ecobee thermostat and was curious if it is still true that the only valid options are home, away, or sleep that can be called from the HomeKit Controller?
Does it matter where the custom scenes are created to be able to call from HomeKit?
From this video, it seems like more HomeKit scenes can be created, but it must be done from the Ecobee app? I also see a note in ecobee’s support that says “The ecobee app features additional scene functionality not available in the Apple Home app”. I was wondering if creating the scenes in this way affected your ability to call those custom scenes from Home Assistant via HomeKit? Thanks!
I have an older Ecobee3. You might want to add as a prerequisite that you need a HomeKit-compatible Ecobee (the original Ecobee3 does not appear to be compatible.)
I assume nobody has figured out a way to communicate locally with the non-HomeKit Ecobees since they are presumably designed only to communicate with the Ecobee servers?
My ecobee 3 has the HomeKit functionality. My ecobee3 states a version number of 4.8.7.134. I’ve had these units for many years.
@jbonzey yes, you have a Homekit-Compatible Ecobee3. Not all of us are so fortunate. See here for Ecobee’s Homekit documentation.
I am migrating from Ecobee cloud. I recommended the device from the ecobee cloud site … reset the device, then configured it back onto the network. When it was discovered I used the Homekit code displayed on the device … and it now appears in HA. But when I check out the Home app, it says accessory not responding.
Thoughts?
Thanks for the now 2-year old write up! I’m a new Ecobee user and struggling a bit with this part. I want to use HA scheduling but set the comfort setting on the Ecobee instead of a target temperature.
I’m unable to target my Ecobee when trying to use the set preset mode action, so I take that to mean I need to create a custom select helper, which I have done. But what action do I then use to take the selected option to set the comfort mode on my Ecobee?
I think I do what you are targeting. On Ecobee I have my Home, Away, and Sleep comfort settings set and I’ve set the schedule to something general but set hold duration to “until you change it”. That way Home Assistant changes persist. I have allowed follow me for temperature balancing and eco+ for smart away only.
For changing the comfort setting I use the action select.select_option and give the option of “Home” “Away” etc. No temperature settings in my Home Assistant automation, just select.select_option. Side note, in the visual editor it looks like the action is called select: select
Great write up @automateit, thank you!
Wondering if you or anyone knows whether thermostat sensors are available via the local HomeKit integration. If so, I can’t seem to find it.
To be more specific, Ecobee differentiates between the thermostat’s temperature which is an integrated (average?) measure of temperature for all participating sensors, whereas a sensor’s temp is of course the reading for an individual sensor. And a thermostat itself can and does have its own temp sensor, distinct from the integrated one. It’s essentially a measure of temperature for the room the thermostat is located in.
I have no problem getting the physical sensors (fka, lil bee) to show up in the integration, but there’s no way I can find to have the thermostat’s sensor show up.
Anyone know? TIA…
Interesting - I never really noticed this before! I don’t have a use case the specifically requires the t-stat to be used as an individual sensor I suppose, but if you need this, it appears that the only way to get the non-averaged temperature is to use both Homekit and the Ecobee (cloud-based) integration, which does report the t-stats true temp. At least, that is what I am seeing on my system.
Think I finally discovered the corrected answer. TL/DR,see the picture below.
Turns out the separate sensor device is the local temp and the temperature entity on the climate device is the zone temp. The two obviously co-vary, but are distinct. I had been assuming (incorrectly, as it turns out) they were the same logical reading because the values were the same every time I looked.
So, as an experiment, I put one of the zone’s standalone (not the thermostat’s) temp sensors in my fridge. The two values quickly diverged and it became clear.
Hopefully this helps others, though it’s an edge case that’s pretty far out there. Thanks again for your write-up. Major kudos to you.
Is anyone else hitting this limitation? max_temp: 81 - And I can’t even set it to 81, I have to settle for 80 because calling 81 triggers a rounding error that is just a touch above 81 since Homekit uses celcius.
Most keep their thermostats much lower I’m sure, but the spec for ecobee says it can go to 92. Although, from what I have read, this is a quirk of not homekit directly, but HAP and that re-pairing the device may give me a higher value.
For me I need this to be no less than 85 and it’s causing a lot of issues. I used to be integrated through the official Ecobee API, but my key magically went missing and the URL for the dev logins is no more. I hear if you have a key they still work, but you can’t get new ones. Ecobee support has been most unhelpful simply giving me canned replies.
This isn’t what I’m seeing… In the non-homekit integration I have a consistent delta of 4-5 deg that I can see between the top “currently:” and a sensor exposed that says just “Temperature”, and I know that my living room (where the thermostat is) runs hot compared to where the other two sensors are. In the HomeKit version the exposed sensor is called “Current temperature” and always is the same as the top part “Currently:”. I can also confirm the integration’s sensor’s value by looking under “sensors” at the Ecobee website which shows the true reading at the thermostat itself.
Maybe if I enabled “Follow Me” then I’d have the same experience you are having, but I’m seeing the same thing that @automateit is.
Thanks for this guide. The most important thing it taught me was that I needed to use both integrations simultaneously, as each version has specific advantages:
  • Homekit’s motion and occupancy sensors are much faster, immediately occupancy detection, as well as a motion entity which the API doesn’t offer. (motion sensor seems to have a cooldown of about 4 minutes after clearing, even if motion occurs between then).
  • HomeKit offers ##.## level of accuracy for temperature, and it seems to update sooner, however I’m not seeing more update points than the API. Surprising, I seem to recall hearing the sensors update much more often since it’s local.
  • HomeKit control is indeed much faster when switching modes and temperatures.
  • API integration offers equipment_running attribute that has the proper other stages (like compCool1, compCool2, fan, etc). HomeKit only offers hvac_action (which is only cooling, fan, and heating). I use PowerCalc to estimate power usage depending on active stages of my multi-stage heat pump.
  • API integration also has a separate fan attribute to show if the fan is running. hvac_action for HomeKit shows fan, but not when also cooling/heating.
  • As mentioned above, HomeKit has no access to preset modes.
Anyway, that’s the most I’ve been able to see so far. As suggested I’ll continue to use both integrations and maybe disable overlapping entities to keep things clear.
Homekit seems to have a clear hold entity, which is great if I set the mode manually, but when I press it, the mode stays on hold.
