Also having this issue - ‘daily’ is undefined. Has anyone been able to get it working?
Okay I’ve managed to fix it!
I put this in my configuration.yaml where ‘home_2’ is my weather entity.
template:
- trigger:
- platform: time_pattern
hours: /1
- service: weather.get_forecasts
entity_id: weather.home_2
type: daily
response_variable: daily
- name: Daily Weather
unique_id: weather_forecast_daily
state: "{{ now().isoformat() }}"
attributes:
forecast: "{{ daily['weather.home_2'].forecast }}"
Then I’m able to access the forecast data in a similiar way to before. I’m using mine in an automation:
🌞 Weather forecast today: {{ states.sensor.home_condition_today.state }}.
Temp: {{state_attr('sensor.daily_weather','forecast')[0].temperature}} °C // {{state_attr('sensor.daily_weather','forecast')[0].templow}} °C
UV Index: {{ state_attr('sensor.home_uv_index','level').capitalize() }}
Pollen: {{ state_attr('sensor.home_grass_pollen_today','level').capitalize() }}
Mould: {{ state_attr('sensor.home_mould_pollen_today','level').capitalize() }}
Tree Pollen: {{ state_attr('sensor.home_tree_pollen_today','level').capitalize() }}
Ragweed Pollen: {{ state_attr('sensor.home_ragweed_pollen_today','level').capitalize() }}
Next 4 days: {{state_attr('sensor.daily_weather','forecast')[1].condition}} | {{state_attr('sensor.daily_weather','forecast')[2].condition}} | {{state_attr('sensor.daily_weather','forecast')[3].condition}} | {{state_attr('sensor.daily_weather','forecast')[4].condition}}
Temperature: {{state_attr('sensor.daily_weather','forecast')[1].temperature}} °C | {{state_attr('sensor.daily_weather','forecast')[2].temperature}} °C | {{state_attr('sensor.daily_weather','forecast')[3].temperature}} °C | {{state_attr('sensor.daily_weather','forecast')[4].temperature}} °C
Precipitation: {{state_attr('sensor.daily_weather','forecast')[1].precipitation}} mm | {{state_attr('sensor.daily_weather','forecast')[2].precipitation}} mm | {{state_attr('sensor.daily_weather','forecast')[3].precipitation}} | {{state_attr('sensor.daily_weather','forecast')[4].precipitation}} mm
The difference is before I was using:
{{ state_attr(‘weather.home_2’, ‘forecast’)[0].temperature }}
and now it is (where ‘daily weather’ is the name I have given my template sensor):
{{state_attr(‘sensor.daily_weather’,‘forecast’)[0].temperature}}
A small change that has been fiddly to figure out. Other templates I have seen have created a template attribute for each forecast attribute but doing it this way means it’s a bit easier to query each one.
yeah, I did the same as you and it worked!
did this works for you?
{{ daily }} returns as empty string “” so when im trying to set the attributes.forecast to:{{ daily[‘weather.my_weather’].forecast }} i get null on my sensor
am i missing something?
btw: invoking the same service with same entity_id from the hassio services returns a good result
Which weather integration are you using?
I’m late to this party and trying to fix an existing automation that gives me a summary forecast for the day, by parsing the hourly’s to give me highs and lows, then sending it to me as a push notification.
Since the change, which I knew was coming, its now broken the original implementation, but I’ve attempted to fix it but its still showing ‘none’ and ‘unknown’ for temperatures and conditions. This is my attempt to fix it:-
alias: Todays Temperature
description: ""
- platform: time
at: "07:30:00"
- platform: homeassistant
event: start
condition: []
entity_id: weather.forecast_home
type: hourly
response_variable: forecast_data
- service: notify.mobile_app_xx_phone
title: Daily Forecast
message: >-
Good Morning! The temperature outside is currently
{{state_attr('forecast_data.forecast[0]','temperature')}} degrees,
{%set highof = state_attr('forecast_data','forecast') |
selectattr('datetime', 'search', now().timestamp() |
timestamp_custom('%Y-%m-%d')) | map(attribute='temperature') | max %} {%
if highof is defined and highof %} with a high of {{highof}} degrees
{%endif%} {%set lowof = state_attr('forecast_data','forecast') |
timestamp_custom('%Y-%m-%d')) | map(attribute='temperature') | min %} {%
if lowof is defined and lowof %} and a low of {{lowof}}{%endif%}. The
weather is forecast to be {{states('weather.forecast_home_hourly')}}{%
set currently_raining = states('weather.forecast_home_hourly') ==
'rainy' %}{%set check_for_rain =
state_attr('weather.forecast_home_hourly','forecast') |
selectattr('condition','equalto','rainy') | list%}{%if not
currently_raining%}{% if check_for_rain is defined and check_for_rain %}
and rainy. {% else %}, with no rain. {%endif%} {%else%}. {%endif%} The
house is currently
{{state_attr('climate.main_house','current_temperature')}} degrees.
mode: single
I’ve not attempted to fix the whole script, just the first three state_attr calls (current temperature, high for the day, and low for the day). The remainder I’ve left using the older mechanism until i figure out what I’m missing to fix the first ones.
Any help would be appreciated.
UPDATE:-
Looking at the thread above, I changed the first call to get the current temperature to:-
{{state_attr('forecast_data','forecast')[0].temperature}}
and it still doesnt work… I get an error in the logs:-
None has no element 0
You are calling the service directly into a response variable of ‘forecast_data’ so I think using this instead should work:
"{{ forecast_data['weather.forecast_home'].forecast[0].temperature }}"
Perfect… I’ve not done that before. I’ve also corrected the rest of the script based on this and its working… ty!
I’m having the same issue with unavailable and have tried multiple ways to resolve. For me, the Met.no integration is referenced as weather.forecast_home. I used the template sample and modified it to below. I’ve created this in the configuration.yaml file, tried it in the templates.yaml file and in the template sensor helper and they all show unavailable, even after rebooting HA and the server. If I run the get.forecasts service, it get the forecast and if I check weather.forecast_home from the entity states, I get the forecast. The code is:
template:
- trigger:
hours: /1
type: hourly
response_variable: hourly
- name: Temperature forecast hourly
unique_id: temperature_forecast_hourly
state: "{{ hourly['weather.forecast_home'].forecast[0].temperature }}"
unit_of_measurement: °F
i guess i had a typo somewhere, all work good now thanks!
btw: im using accuweather
I checked today the integration and even if it should update every hour or at HA startup, I have inconsistent data.
Last update time is this morning 6.40am when I have a weekly reboot of HA instance. No update in the following hours. Moreover, the forecast days are still the one of the first run of 1 week ago. They go from 7th to 12th April. Are anyone having this problem?
No errors shown in code:
- trigger:
hours: /1
event: start
type: daily
entity_id: sensor.weather_daily
- name: Weather Daily
state: "{{ states('sensor.weather_daily') }}"
attributes:
temperature: "{{ state_attr('sensor.weather_daily', 'temperature') }}"
dew_point: "{{ state_attr('sensor.weather_daily', 'dew_point') }}"
temperature_unit: "{{ state_attr('sensor.weather_daily', 'temperature_unit') }}"
humidity: "{{ state_attr('sensor.weather_daily', 'humidity') }}"
cloud_coverage: "{{ state_attr('sensor.weather_daily', 'cloud_coverage') }}"
pressure: "{{ state_attr('sensor.weather_dailye', 'pressure') }}"
pressure_unit: "{{ state_attr('sensor.weather_daily', 'pressure_unit') }}"
wind_bearing: "{{ state_attr('sensor.weather_daily', 'wind_bearing') }}"
wind_speed: "{{ state_attr('sensor.weather_daily', 'wind_speed') }}"
wind_speed_unit: "{{ state_attr('sensor.weather_daily', 'wind_speed_unit') }}"
visibility_unit: "{{ state_attr('sensor.weather_daily', 'visibility_unit') }}"
precipitation_unit: "{{ state_attr('sensor.weather_daily', 'precipitation_unit') }}"
forecast: "{{ daily['sensor.weather_daily'].forecast }}"
Your target entity ID should be your weather integration which will start with ‘weather.’, as this is what you are calling the service for, try changing this and see if it helps.
Also, are you using the met.no integration? I’ve noticed in my logs that it often seems to fail on an automation with an API error.
if I do against
I get error in the log. I tried to revert to the previous entity but I get error again, like if it worked only the first time last week.
Getting these now:
Logger: homeassistant.helpers.event
Source: helpers/template.py:588
First occurred: 12:49:33 PM (22 occurrences)
Last logged: 12:49:33 PM
Error while processing template: Template<template=({{ state_attr('sensor.weather_daily', 'forecast')[3].temperature | round }}) renders=2>
Error while processing template: Template<template=({{ state_attr('sensor.weather_daily', 'forecast')[3].templow | round }}) renders=2>
Error while processing template: Template<template=({{ as_timestamp(state_attr('sensor.weather_daily', 'forecast')[3].datetime) | timestamp_custom('%d') | int }} {{ as_timestamp(state_attr('sensor.weather_daily', 'forecast')[3].datetime) | timestamp_custom('%b') }}) renders=2>
Error while processing template: Template<template=({{ state_attr('sensor.weather_daily', 'forecast')[3].temperature | round }} / {{ state_attr('sensor.weather_daily', 'forecast')[3].templow | round }} °C) renders=2>
Error while processing template: Template<template=({% from 'tools.jinja' import umidita_assoluta %} {{ umidita_assoluta('sensor.gw1100a_temperature_2', 'sensor.gw1100a_humidity_2') }}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2218, in forgiving_float_filter
return float(value)
ValueError: could not convert string to float: 'unknown'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 586, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2545, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2221, in forgiving_float_filter
raise_no_default("float", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1849, in raise_no_default
raise ValueError(
ValueError: Template error: float got invalid input 'unknown' when rendering template '{{ states("sensor.google_travel_time") |float - state_attr("sensor.google_travel_time", "duration")| replace(" mins", "") | float }}' but no default was specified
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 712, in async_render_to_info
render_info._result = self.async_render(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 588, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: float got invalid input 'unknown' when rendering template '{{ states("sensor.google_travel_time") |float - state_attr("sensor.google_travel_time", "duration")| replace(" mins", "") | float }}' but no default was specified
Integration is with met.no, but I don’t see error in calling their api
That seems to be saying that it is getting unknown from calling the service. I think it might be an issue with the integration.
I had to click ‘load full logs’ for it to show me the error. Also if I went to the actual weather integration it was showing as unavailable.
Try reloading the integration?
integration works fine, I can read all data with daily/hourly forecast.
If I call the service alone it works:
type: daily
if I call it in the template it seems there is no return (I tried to create a new sensor too):
and of course when it tries to get the attributes it fails.
- trigger:
hours: /1
event: start
type: daily
attributes:
pressure: "{{ state_attr('sensor.weather_daily', 'pressure') }}"
I’m kinda confused where is the problem.
I changed the variable and now it populates the sensor, but so far the /1 trigger doesn’t seem to work. Just the startup trigger works
- trigger:
hours: /1
event: start
type: daily
state: "{{ states('weather.forecast_home') }}"
attributes:
temperature: "{{ state_attr('weather.forecast_home', 'temperature') }}"
dew_point: "{{ state_attr('weather.forecast_home', 'dew_point') }}"
temperature_unit: "{{ state_attr('weather.forecast_home', 'temperature_unit') }}"
humidity: "{{ state_attr('weather.forecast_home', 'humidity') }}"
cloud_coverage: "{{ state_attr('weather.forecast_home', 'cloud_coverage') }}"
pressure: "{{ state_attr('weather.forecast_home', 'pressure') }}"
pressure_unit: "{{ state_attr('weather.forecast_home', 'pressure_unit') }}"
wind_bearing: "{{ state_attr('weather.forecast_home', 'wind_bearing') }}"
wind_speed: "{{ state_attr('weather.forecast_home', 'wind_speed') }}"
wind_speed_unit: "{{ state_attr('weather.forecast_home', 'wind_speed_unit') }}"
visibility_unit: "{{ state_attr('weather.forecast_home', 'visibility_unit') }}"
precipitation_unit: "{{ state_attr('weather.forecast_home', 'precipitation_unit') }}"
forecast: "{{ daily['weather.forecast_home'].forecast }}"
So I was using an if statement that depends on the weather entity.
{{ states.weather.forecast_ouachita_hills.attributes.forecast[0].templow | float >= 30 }}
if the weather was under 30 degrees it would turn the heat on if not it would turn it off.
How do I make a template for the new system?
Is this a sensor template? It doesn’t seem to work. I load my sensors thru yaml includes via sensor: !include_dir_merge_list includes/sensors
Using this block:
# Old weather style
hours: /1
event: start
type: daily
entity_id: weather.openweathermap
- name: Old forecast style weather
state: "{{ states('weather.openweathermap') }}"
attributes:
temperature: "{{ state_attr('weather.openweathermap', 'temperature') }}"
dew_point: "{{ state_attr('weather.openweathermap', 'dew_point') }}"
temperature_unit: "{{ state_attr('weather.openweathermap', 'temperature_unit') }}"
humidity: "{{ state_attr('weather.openweathermap', 'humidity') }}"
cloud_coverage: "{{ state_attr('weather.openweathermap', 'cloud_coverage') }}"
pressure: "{{ state_attr('weather.openweathermap', 'pressure') }}"
pressure_unit: "{{ state_attr('weather.openweathermap', 'pressure_unit') }}"
wind_bearing: "{{ state_attr('weather.openweathermap', 'wind_bearing') }}"
wind_speed: "{{ state_attr('weather.openweathermap', 'wind_speed') }}"
wind_speed_unit: "{{ state_attr('weather.openweathermap', 'wind_speed_unit') }}"
visibility_unit: "{{ state_attr('weather.openweathermap', 'visibility_unit') }}"
precipitation_unit: "{{ state_attr('weather.openweathermap', 'precipitation_unit') }}"
forecast: "{{ daily['weather.openweathermap'].forecast }}"
The YAML check complains:
Invalid config for 'template' from integration 'sensor' at includes/sensors/weather.yaml, line 257: required key 'sensors' not provided
Invalid config for 'template' from integration 'sensor' at includes/sensors/weather.yaml, line 264: 'action' is an invalid option for 'sensor.template', check: action
Invalid config for 'template' from integration 'sensor' at includes/sensors/weather.yaml, line 271: 'sensor' is an invalid option for 'sensor.template', check: sensor
Changing sensor
to sensors
gives different validation errors:
Invalid config for 'template' from integration 'sensor' at includes/sensors/weather.yaml, line 271: expected dictionary for dictionary value 'sensors', got [{'name': 'Old forecast style weather', 'state': "{{ states('weather.openweathermap') }}", 'attributes': {'temperature': "{{ state_attr('weather.openweathermap', 'temperature') }}", 'dew_point': "{{ state_attr('weather.openweathermap', 'dew_point') }}", 'temperature_unit': "{{ state_attr('weather.openweathermap', 'temperature_unit') }}", 'humidity': "{{ state_attr('weather.openweathermap', 'humidity') }}", 'cloud_coverage': "{{ state_attr('weather.openweathermap', 'cloud_coverage') }}", 'pres
Indeed sensor template(s) should have correct syntax to parse the output of the integration.
This is my working example (I am using Open-Meteo as source).
VS Code validation for some reason showing error, but the code is valid.
- trigger:
hours: /1
entity_id: weather.ozollapas
type: daily
response_variable: my_forecast
- name: Total Expected Precipitation Today
unique_id: 3d7abfa1-4e24-481c-a956-dfe71a8c0d9b
icon: mdi:weather-pouring
unit_of_measurement: "mm"
state: >
{% set precipitation_probability = my_forecast['weather.ozollapas'].forecast[0].precipitation %}
{{ precipitation_probability | float(0) | round(1) }}
- name: Temperature Low Expected Today
unique_id: 693de803-37b0-4ba7-88ff-e753cda83b1d
icon: mdi:thermometer-low
unit_of_measurement: "°C"
state: >
{% set temperature_low = my_forecast['weather.ozollapas'].forecast[0].templow %}
{{ temperature_low | float(0) | round(1) }}
- name: Temperature Expected Today
unique_id: 61282551-5337-4061-bf04-c9287fd90e54
state: >
{% set temperature = my_forecast['weather.ozollapas'].forecast[0].temperature %}
{{ temperature | float(0) | round(1) }}
- name: Wind Speed Expected Today
unique_id: 37aa9b62-4b15-47fd-8ce7-da66ec59771e
icon: mdi:wind-turbine
unit_of_measurement: "m/s"
state: >
{% set wind = my_forecast['weather.ozollapas'].forecast[0].wind_speed %}
{{ wind | float(0) | round(1) }}
can someone please help me, I tried to use the template from here but it does not work, my virtual sensors show unavailable.
It is very basic, I only want to know tomorrow’s min and max forecast temperature in two sensors max and min.
Can someone please tell me what the issue is here:
template:
- trigger:
- platform: state
type: daily
- name: Tomorrow Max Temp
state: "{{ daily['weather.forecast_home'].forecast[1].temperature }}"
attributes:
- name: Tomorrow Min Temp
state: "{{ daily['weather.forecast_home'].forecast[1].templow }}"
attributes:
Now it works somehow, I just edited the name to forecast_sickenhausen … weird. I leave it here as a simple example.
Update 2: It is weird, I tried with more sensors. For this to work I had to disable the weather entity and enable it again. After this, the sensors had values immieadiatle.
