How to modify Dashboard gaps?
HA is great, but something is always (debatable) !
Why is a distance here?
Unbenannt
And why I can’t change this distance or behaviour (easily accessible)?
For example, this space causes unnecessary scroll bars if the dashboard view (raw configurationeditor) is configured like this:
full_height: true
And:
why the rounded corners? I would like to have real corners here or at least the configuration option for real corners ! (p.ex. the raw configurationeditor has real corners, too. why you don’t give it rounded corners? Because it doesn’t look bloody well !)
Thank you very much in advance!
So long
Pc
You can customize an appearance in a custom theme.
Thanks for your response.
Would be nice to tell me HOW.
Why do we have to pull everything out of everyone’s nose here? This is exhausting, especially since as a beginner you don’t have an overview.
Why is it so difficult for some people to answer in a beginner-friendly way?
Now I’m back to searching with keywords and then I find old threads or videos with configuration examples that no longer work or you don’t know how and where to use/put them. Videos like this don’t help me.
If someone has a solution to a problem, why isn’t the documentation adapted accordingly, etc.?
A message to the moderator team should be possible - there has to be that much time… imo
So long PC
current:
  1. I’m looking for a way to display a sensor value in the HA-website-dashboard (html file).
  2. I’m looking for a way to overwrite a line in a css file depending on the sensor status.
  3. Thank you
You asked a question in WTH.
WTH is mainly for asking about things which are not possible yet.
I told you that it IS possible - themes.
Now this WTH thread is supposed to be abandoned and you should go to Configuration / Frontend , ask a question there and get a help.
…but not HOW ! (example, links). Is THIS too much for you? Why you answer then?
…and without a solution, again.
A useless answer is worse then no answer, imo, so…
Happy holidays and a happy new year. Stay healthy.
So long
Pc
I see this thread was properly moved to Configuration-Frontend - same thing I proposed you. And you keep blaming… Not sure anyone has a magic Xmas mood then.
