I have 4 foscam cameras installed and working. But I need to modify one of the ip addresses. I can’t find where to modify, yaml, etc.
Do I need to just remove the old one and re-install with the new ip?
thx
thx
I assume you are using the foscam integration configured via the UI for the camera?
if so then I think that’s the only way.
Thx for the reply.
Yes, I am using the foscam integration.
Sounds like this should be a capability, maybe in the next revision…
...>Mike
doubtful.
there are many integrations that are configured thru the UI that don’t have this capability. And they’ve been that way for a long time so I doubt it will change.
