I use Samba Backup addon for HA backup. I would like to display the info on UI such as(if all of them are possible somehow):-
Backup Status: Running or Not Running Note :- I am not looking for Addon Status
Speed:
Last Finished:
Backups local: # of backups
Backups remote: # of backups
Warning: display a list of warnings
Any help is appreciated and thank you.
-Shan
tom_l
August 16, 2022, 10:49pm
2
Pretty sure these are the only sensors available:
type: entities
title: Samba Backup
entities:
- entity: sensor.samba_backup
icon: mdi:file-replace-outline
- attribute: backups_local
icon: mdi:file-outline
type: attribute
- attribute: backups_remote
icon: mdi:file-move-outline
type: attribute
- attribute: total_backups_succeeded
icon: mdi:file-check-outline
type: attribute
- attribute: total_backups_failed
icon: mdi:file-cancel-outline
type: attribute
- attribute: last_backup
icon: mdi:file-clock-outline
type: attribute
show_header_toggle: false
Though I have not checked for quite a while.
EDIT: seems to be up to date: https://github.com/thomasmauerer/hassio-addons/blob/1ffffaaa1df3a954e04cc13cf06329203ede4b2d/samba-backup/DOCS.md#home-assistant-sensor
nickrout
(Nick Rout)
August 16, 2022, 11:11pm
3
Isn’t that all in the addon ui?
tom_l
August 16, 2022, 11:21pm
4
What do you mean?
There is no UI for Samba Backup.
nickrout
(Nick Rout)
August 16, 2022, 11:52pm
5
Sorry I was thinking of the google drive addon.
Having an issue when Addon is not running it does not show anything and bunch of lines with Entity not available.
How do you show in this case ?
tom_l
August 26, 2022, 3:16am
7
I don’t turn the addon off.
For me Addon is not off either. What I meant was it will only show entities info when it is actually doing the backup- if that makes sense. When backlup is finished entities show error as Entity not available.
tom_l
August 26, 2022, 4:05am
9
Ah. I remember that issue now. You need to add this startup automation:
- id: 46ba1b3e-14bc-4237-abb6-e9146eacc575
alias: 'Startup'
platform: homeassistant
event: start
- service: hassio.addon_stdin
addon: 15d21743_samba_backup
input: restore-sensor
Wow, that worked like a charm. I wonder how many more tips are out there that I will come across.
Thanks much!!
tom_l
August 26, 2022, 4:20am
11
