I’m running HA on a Pi4, which is great btw. I’ve another Pi Zero W which is running MotioneyeOS and a camera. Is there a way to monitor the CPU temp? I found the ‘command line’ but I can’t figure out how to define the other Pi, rather than just pulling the temp from the Pi running HA.
I said Pi an awful lot there, I hope that makes sense haha
This is a stretch as a solution, but here goes
Did you use ssh to get the ‘command line’? If so, you can read the CPU temperature like this: cat /sys/class/thermal/thermal_zone0/temp
That is the temperature in C multiple by 1000.
To get fancy you can use ssh to log in and run this: ssh pi@your_pi cat /sys/class/thermal/thermal_zone0/temp | awk '{ print ($1 / 1000.0) }'
Put the public ssh key of the Pi you’re calling from in the destination Pi’s ~/.ssh/authorized_keys.
