Hello, since we can monitor Android device with our home assistant, just installing the android app, I’d like to know if there’s a way to do the same with Windows PC.
Try open hardware monitor.
It is a stock integration.
A server works at least in Win9.
I use SSH Integration from HACS for monitor Linux and Windows over ssh.
I tried glances, but is overkill for what i want, just monitor cpu and temperature usage.
I use System Bridge. It has a core integration.
Basically, all that’s needed is to download and install on your PC. The bridge logo appears in your system tray icons. There’s an option to start it when your PC boots up.
For the integration, just enter your PC’s IP address.
I’ll explore the suggestions, but I have to correct myself about android system, because today I was scrolling the options on my smartphone device and between sensors I didn’t find CPU, memory or disk sensors.
Do you mean Android companion app? I very doubt it has system monitoring sensors… Just curious, do you really need these metrics for this probably mobile or handheld device?
Well, just curiosity.
