How to mount/access "hassos-boot" partition?
On a Raspberry Pi I want to access config.txt in “hassos-boot” partition without shutting down HASS OS, pulling sd card out and accessing it on another system (e. g. Windows client).
How to access the partition using SSH/terminal (maybe a remount with read option)?
ssh root@hassio -p 22222
once inside you get a prompt like ha >
there you type:
login
your prompt will change into #
now you can:
mount /dev/sda1 /mnt/
cd mnt/
vi config.txt
and then reboot. I hope this helps!
A little bit late, but you will find the config.txt in /mnt/boot
